skunk 2 stage2 with valves?
Old Apr 18, 2006 | 09:18 AM
Speed Infliction's Avatar
Default skunk 2 stage2 with valves?
I was wondering what valves to get with s2s2 cams. should i also get them oversized or not? I was leaning towards the s2 valves but im not sure and i don't know if i should get them oversized.
Old Apr 18, 2006 | 09:21 AM
Circuit Star-29's Avatar
Default Re: skunk 2 stage2 with valves? (Fayzeless)
Stick w/ OEM ITR valves...
Old Apr 18, 2006 | 09:26 AM
Black R's Avatar
25 Year Member
^ what he said..... otherwise you may have clearance issues with valve to valve and/ or valve to piston contact.....
Besides, there are plenty on here making 250, 300, 400, 500, 600 ,700 , 800whp+ with stock valves.....
Old Apr 18, 2006 | 09:30 AM
Default Re: (Black R)
do you think that ther will be a problem with those cams making the valves touch the piston with 12.5:1 compression? also will i need to get springs and retainers for that cam setup
Old Apr 18, 2006 | 09:58 AM
Default Re: (Fayzeless)
anybody?
Old Apr 18, 2006 | 01:09 PM
When you start venturing into the higher compression ratios, you need to start playing with cam timing. This is where claying a motor will be beneficial... At zero cam timing there shouldn't be a problem with contact...
albeit, the Skunk stg 2s will not get you all the power you're looking for ... I would seriously consider a larger cam if you want to make the most power...Maybe a Toda C
Old Apr 19, 2006 | 10:24 AM
Default Re: (Circuit Star-29)
I have an option of getting the jun 3's used for $405 a brand new set of s2s2 pro series for $600. you think that the toda c's are more potent than the pro series? I thought it was the other way around. let me know which one you would buy. also what sprinds and retainers should i go with? by the way after i rebuild me motor i will give the credit to the people that help me out the most on here to blueprint out my motor. so far i have eagle rods, je 12.5:1 pistons, aem feul rail and regulator,fidanza flywheel, aem intake,crane cam gears,etc.....now i have to get still is hondata and wide band, camshafts, complete head job, good tuner, motor clayed, new clutch,feul pump, injectors. what do you think about that? am i missing anything?
Old Apr 19, 2006 | 11:32 AM
Black R's Avatar
25 Year Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fayzeless &raquo;</TD></TR><TR><TD CLASS="quote">I have an option of getting the jun 3's used for $405 a brand new set of s2s2 pro series for $600. you think that the toda c's are more potent than the pro series? I thought it was the other way around. let me know which one you would buy. also what sprinds and retainers should i go with? by the way after i rebuild me motor i will give the credit to the people that help me out the most on here to blueprint out my motor. so far i have eagle rods, je 12.5:1 pistons, aem feul rail and regulator,fidanza flywheel, aem intake,crane cam gears,etc.....now i have to get still is hondata and wide band, camshafts, complete head job, good tuner, motor clayed, new clutch,feul pump, injectors. what do you think about that? am i missing anything?</TD></TR></TABLE>
You posted this in another thread and I replied there.
The valve reliefs in the pistons *may* need to be opened up a bit depending on cam choice. Your engine builder should be competent enough to handle this. CLAY CLAY CLAY.
r1de4life
Sep 12, 2007 11:06 AM
sibluecrx
Feb 3, 2007 02:21 PM
dand39
Feb 16, 2005 11:47 PM
kwik93si
May 2, 2003 03:58 PM
