Want to confirm:. Is there any way to jump an obd II ecu to find cel codes?
Old Apr 18, 2006 | 08:58 AM
peacexisxfree's Avatar
Default Want to confirm:. Is there any way to jump an obd II ecu to find cel codes?
My friend has an 00 civic and the car recently started to throw a cel. Any way to jump or check it without the scan tool?
I am pretty sure it's a no, but I'd like to confirm.
Yeah, retard question, but I have read you can do both, and I have only owned obd I cars.
TIA
Old Apr 18, 2006 | 09:04 AM
EE_Chris's Avatar
Default Re: Want to confirm:. Is there any way to jump an obd II ecu to find cel codes? (peacexisxfree)
You do not need a scan tool to check the blink codes for OBDII. You need a scan tool to check the "P" codes.
Old Apr 18, 2006 | 09:05 AM
Default Re: Want to confirm:. Is there any way to jump an obd II ecu to find cel codes? (EE_Chris)
so you can jump it just like obd I...
Thanks...
Old Apr 18, 2006 | 09:52 AM
civic93@8psi's Avatar
GO TO AUTOZONE
its freeeeeeeeeeeeeee
Old Apr 18, 2006 | 10:20 AM
SkoundrelUSA's Avatar
cute little bastard
Default Re: (civic93@8psi)
Only for the SRS codes. For P codes...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic93@8psi &raquo;</TD></TR><TR><TD CLASS="quote">GO TO AUTOZONE
its freeeeeeeeeeeeeee</TD></TR></TABLE>
BY: Iam7head
Due to popular demands, here is the guideline.
*car- 2002 accord 4cylinder(should work for all honda)
*what you need to know- your accord gen/year location of the srs service connector(MES or something)
*tools- paperclip, flashlight
The MES connector is located in the backside of the hood release latch for 6th gen accord.
The SRS connector's evil twin brother. The real deal is the one I am pointing at, the one that harder to reach. They both have the similar color of wires coming out so don't be fooled.
Another view
Insert paperclip
For the poor souls without helms.
Erasing the DTC memory/resetting SRS light
1) turn ignition switch off
2) connect the scs service connector to the MES connector. Do not use a jumper wire
3) turn igition switch to on
4) The SRS indicator light will come on for about 6 seconds, and then go off. Remove the SCS service connector from the MES connector within 4 seconds after the light comes on
5) The SRS indicator will come on again. Reconnect the SCS service conector(or in ghetto world of honda, paperclip) to the MES connector(read: the yellow connector, see picture) within 4 seconds after the light comes on.
6) When the SRS indicator light goes off, remove the SCS service connector from the MES connector within 4 seconds.
7) The SRS indicator light will blink 2 times indicating that the memory has been errased/clear.
8) turn the ignition switch to off and wait for 10 seconds.
I think there's some similar article/post in the past, but none with pictures, see if this would help some of the visual learning generations of honda owners. make it sticky will ya?!
S_F
Feb 29, 2012 04:27 AM
EKSedAndy
Dec 13, 2009 04:28 PM
wesgsr
Sep 10, 2006 12:19 PM
