Eclipse turbo for a CIVIC99 si ??
n e boddy ever done an eclipse turbo for a civic si 99.. my friend to ld me that it perfectly fits also.... and i would just need to find a manifold for a civic n im set.. can anyone please help me im just trying to get a turbo for my si.. thnx
welcome to like 7 years ago.. yes it will work.. you can make any turbo work. its all about the mani, and the pipeing. go to homemadeturbo.com. if you are amazed by what your friend said, then yuor going to flip when you see what they do on there..
Is the turbo on the evo the same as the turbo on the GS-T or GSX eclipses?
If not, I'd wonder how the evo turbos would do on civics, probably have a nice haul since the body features are the same (both light weight, oppose to the eclipse which was heavy)
Ah I"m just thinkign out loud ~~ word
EDIT:
OH yeah, sorry about on topic
on topic:
yeah, ur friend is right, just need the right turbo manifold, most piping is standard size (I forgot, but it MIGHT be 2.5 inches, find that out..the rest is all pretty standard 'cept for the whole manifold/turbo/wastegate part..
EDIT:
on topic:
if you use an eclipse stock turbo, use one from a first gen eclipse. they can make a little more boost than the second gen.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate »</TD></TR><TR><TD CLASS="quote">Is the turbo on the evo the same as the turbo on the GS-T or GSX eclipses. </TD></TR></TABLE>
the evo's have a differnt turbo than the eclipse. the evo III witch had the same 4g63 engine as the eclipse, came with a nice 16g turbo that would work realy well for you. it will cost more to get one, but look on ebay they go pretty cheap. i dont know a hole lot about the new evo's turbos to make an responce on that, but they are different.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate »</TD></TR><TR><TD CLASS="quote">If not, I'd wonder how the evo turbos would do on civics, probably have a nice haul since the body features are the same (both light weight, oppose to the eclipse which was heavy)
you would want to match the turbo to the engine size, not the car weight. your engine is only a 1.6L if you go with too big of a turbo you will have too much lag.
thnx for da repl guys.. im just wondering rite now wer to get dis ecplipse turbo from for a good price... n e body knows website.. maybe ebay... but wat are they called.. wat are the things i need to order....??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eckolistik »</TD></TR><TR><TD CLASS="quote">thnx for da repl guys.. im just wondering rite now wer to get dis ecplipse turbo from for a good price... n e body knows website.. maybe ebay... but wat are they called.. wat are the things i need to order....??</TD></TR></TABLE>
how much are you looking to spend, i can look for one for you.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eckolistik »</TD></TR><TR><TD CLASS="quote">mah friend saed i can get eclpise turbo for like 300 dollars i think.. n den he brought up about doing a b20 block instead 500 dollars n 350 hp rite away.... hmmmm???</TD></TR></TABLE>
your not going to get 350hp from just putting a b20 block on your b16 head (crvtec). if you turbo the crvtec you would have a lot more potential for horsepower over your 1.6L block and could reach 350 hp. but just putting the block and head together with some good tuning, you might get 200hp.
check out this link on making your own turbo kit. http://www.cse.uconn.edu/~yele....html
I had a 1G eclipse with a 14B turbo (stock turbo) and the car was fast.I was pushing 15psi which is the max for the stock fuel system.But the turbo can run up to 20 psi.The 16G will run u up to 25 psi.Go to dsmtunners.com and they have 14B's for like $200.They are nice litter turbos.
Just get a Garret. The thermal convection waterjacket provides passive cooling at shutdown with no moving parts, so no need for a turbotimer. You can also get 'em with VNT (variable Nozzle Turbo) so they spool quickly, then deploy the vanes to full-open mode for increased breathing. Saves you having to plumb up a twin-turbo system.
