Suspension, Steering, Tires
Old Apr 17, 2006 | 07:49 PM
O RLY's Avatar
Default Suspension, Steering, Tires
Well tomorrow I'm pretty much tackling a trifecta of work. I'm replacing almost every bushing in my '94 EJ with ES bushings, replacing my inner tie rods with new OE inners, and ordering new tires.
First off, how easy is it to chang the inner tie rods. I've noticed the boots around my existing ones are worn and both clips are gone. Should I buy new OEM boots and clips for both sides. I assume this will prolong the life of my inner tie rods.
Second is tires. I'm really leaning towards the new Hankook Ventus 215/45/16, but will a 225/45/16 fit. I have an H22 swap which is seeing some high boost this summer, so I want to be able to hook up, and the fact is that more surface are = better hookup when it comes to tires.
Just wanted to see if there's anyone who can throw a little advice on this subject for me.
Thanks,
Rob
Old Apr 17, 2006 | 08:00 PM
nello a.'s Avatar
might want to give more info. wheel model/offset/size
Old Apr 17, 2006 | 08:06 PM
O RLY's Avatar
Default Re: (nello a.)
Good point. They're 16x7 Axis Lenso VPDs. Can't find the offset, but would there tires rub my inner fender wells? I have the car dropped about 1.5 inches and will set the camber negative for better handling.
Old Apr 17, 2006 | 08:10 PM
wheelmanbg's Avatar
Default Re: (O RLY)
That's a good tire choice!
I have 205/40/16 and never had a problem
I don't think 45 are that much bigger than 40s
Old Apr 18, 2006 | 05:36 AM
O RLY's Avatar
Default Re: (wheelmanbg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wheelmanbg &raquo;</TD></TR><TR><TD CLASS="quote">That's a good tire choice!
Yeah but a 205/40 is a world of difference from a 225/45.
90210tegrunner
Aug 9, 2017 12:27 PM
duf2570
Mar 2, 2014 06:24 PM
nonpoint986
Feb 9, 2012 03:13 PM
BrayzieEF9
19
Jun 30, 2010 02:42 PM
kepani
Sep 20, 2005 03:29 PM
