srs reset
I have a 1993 acura legend coupe L (2 door) and my airbags deployed after hitting a curb (not very hard even). It also caused both front seatbelts to lock up. I replaced both airbags, the srs module, and the srs piece behind the steering wheel. I also replaced the seatbelts with aftermarket universal seatbelts.
My question is how do I reset the srs light?
Also, can the light be reset and will my airbags still work even though I am using universal seatbelts?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by derick.newton »</TD></TR><TR><TD CLASS="quote">My question is how do I reset the srs light?
Also, can the light be reset and will my airbags still work even though I am using universal seatbelts?</TD></TR></TABLE>
No, you will have to replace the seatbelts with the correct oem parts in order to get the SRS light off. The seatbelts use tensioners and are part of the SRS system. New ones are very expensive, you may be able to find some decent used ones if you look around. Check the for sale/parting out section over at acura-legend.com.
