Cost of whole A/C System
how much is the whole Air Conditioner System for a 93 Integra GSR...i want everything so how much would it be total without installation??? I need it since Texas is about to hit hot temperature
you have to look around really. i dont know the exact price but i sold a condenser, all the lines and the ac compressor, pretty much everthing needed for like 75 bucks. i think that person got a steal. but after searching a second i found this.
http://hondamarketplace.com/zerothread?id=1588835
its not for a gsr but it might work. that should give you a little idea how much they might cost
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EN4CER »</TD></TR><TR><TD CLASS="quote">Will it fit a 97 Civic (1.3 lt) since I can't post there (trial member)? Thanks!</TD></TR></TABLE>
i think that one bracket is different.. also the lines are different as far as the fittings cause of the different refrigerant it uses..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by the_donkey_69 »</TD></TR><TR><TD CLASS="quote">IT SHOULDNT RUN YOU MORE THAN 150 FOR A NICE ONE. GO TO EBAY AND THEY GOT GOOD DEALS FOR EVEN CHEAPER.
Again, turn off your caps lock. ****
</TD></TR></TABLE>Again, turn off your caps lock. ****
Just shop around I know the whole AC system for a civic from honda is about 550.00+ so new is not something you are going to want. Try to find someone that is doing a swap/turbo they are usually looking to get rid of the parts for cheap.
akhom
Jun 23, 2004 10:38 PM
