civic ac question
Re: civic ac question (aktc167)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aktc167 »</TD></TR><TR><TD CLASS="quote">are the 92-95 civic ac the same as the 96+ civics? will a 93 civic ac fit in my 97 civic ex coupe stock motor? thanks.</TD></TR></TABLE>
They switched the coolant type used in 95, so unless you could find some R12 freon, you wouldn't be able to use the older setup unless converted to be compatible with R134.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aktc167 »</TD></TR><TR><TD CLASS="quote">so the only differenece is using the different freons?</TD></TR></TABLE>
The seals in the older system aren't compatible with the new freons. Other than that, I beleive they should fit; but I haven't personally tried it because it's much easier to just install the newer system.
Poey2
01-06-2004 08:52 PM
