1995 Accord odometer and trip-meter get stuck
Old Apr 17, 2006 | 04:32 PM
guymontag's Avatar
Default 1995 Accord odometer and trip-meter get stuck
Pushing the trip-meter reset stalk doesn't help, although it does reset the trip meter just fine. What does help is banging on the dash, but it doesn't always help, only sometimes, and only if I bang hard enough. Anybody have any ideas for a better fix? Or should I consider myself blessed and just accumulate miles while my car stays stuck in a time warp. It'll be good for trade-in value...
Old Apr 17, 2006 | 04:41 PM
BLKFLSH's Avatar
Default Re: 1995 Accord odometer and trip-meter get stuck (likeguymontag)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by likeguymontag &raquo;</TD></TR><TR><TD CLASS="quote"> Or should I consider myself blessed and just accumulate miles while my car stays stuck in a time warp. It'll be good for trade-in value...</TD></TR></TABLE>
Sounds like a good idea to me. Just fix it before you sell it.
Old Apr 18, 2006 | 01:42 AM
civiccoupe94's Avatar
not racking mileage is good for you i think, but you do want to know the miles per gallon your getting and when does the car hits 3,000 miles for an oil change. go to a junk yard and find the speedo section of the cluster. its basically a plug and play deal
Old Apr 18, 2006 | 09:09 PM
guymontag's Avatar
Default Re: (civiccoupe94)
That'll require taking the dash apart, right? That's probably a long procedure, and I don't think the Haynes manual covers that one. Any ideas?
Old Apr 19, 2006 | 04:01 AM
TouringAccord's Avatar
H-T Order of Merit
Default Re: (likeguymontag)
Could be the speedometer itself or maybe the VSS. Does the RPM guage stop when the speedometer stops or is the RPM not affected?
To get the speedometer out, you will need to remove the bezel that goes around the cluster, heating vents and climate control. Once thats removed, you'll then need to unscrew the cluster from it's mounting locations. Pull the cluster out and unplug it. You see some clips along the edge of the cluster and the clear cover, unclip them and pull it apart. Unbolt the speedometer and slide it out. Replace everything in reverse order.
Old Apr 19, 2006 | 01:20 PM
f22 lx's Avatar
same thing happened in my accord, i just went and got a new one and replaced the old one, everything works fine now...mine was stuck for about 3000 miles, then i decided i shuold probably get it fixes
Old Apr 19, 2006 | 07:22 PM
guymontag's Avatar
Default Re: (TouringAccord)
It's definitely the odometer cluster, not the VSS, because the tach is fine, and the odometer seems to get stuck every 100 miles. I'll either get a new odometer or clean and lubricate the old one. Thanks a ton for the dash disassembly outline.
Old Apr 20, 2006 | 03:25 AM
H-T Order of Merit
np
Old Apr 20, 2006 | 06:31 AM
92ehatch's Avatar
my trip meter sticks too, makes a clicking noise
my odometer still works tho, so im not worried about it
blipmode188
Mar 2, 2009 02:00 PM
TheShallot
Aug 1, 2008 10:33 AM
exl_09
17
May 29, 2008 12:47 AM
b20turboteg
Apr 28, 2005 03:40 AM
Shambro84
Feb 23, 2004 05:03 PM
