no reverse lights
Old Apr 17, 2006 | 08:30 AM
HondaEJ7's Avatar
Default no reverse lights
i have a 97 civic hx 5 speed, and i swapped the transmission out for a 95 EX transmission. now for some reason when i put the car in reverse, the reverse lights wont go on. what could be the problem??
Old Apr 17, 2006 | 08:36 AM
EG_H2B's Avatar
Default Re: no reverse lights (HondaEJ7)
check the wiring. there is a little 2 wire switch on the front of the trans. make sure its hooked up
Old Apr 17, 2006 | 08:45 AM
ZipTieGUy's Avatar
yea make shure the reverse switch is hooked up. if it is and it still aint working you can turn the car to "on" and put in reverse and check for continuity between the two wires in the switch. or even faster just pull the reverse switch from your old trany
Old Apr 17, 2006 | 09:03 AM
yee SERIOUS's Avatar
any pics of this switch? i think i'm having the same problem....
Old Apr 17, 2006 | 09:13 AM
EX-T's Avatar
Default Re: (undercoverdc2)
Also check the fuse under the dash!
Old Apr 17, 2006 | 10:00 AM
HondaEJ7's Avatar
fuses are fine
i checked the reverse wire, its in, but maybe its faulty?
Syper
10
Oct 20, 2009 11:34 PM
89 Ef Amzler
Lighting
Oct 9, 2009 08:57 PM
brandon43
Mar 5, 2009 09:28 PM
mustninty
Aug 17, 2004 03:26 AM
AMChev
Oct 14, 2003 05:16 AM
