Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
For Those Running the Moroso RR Oil Pan.
Old Apr 17, 2006 | 06:20 AM
ralphie14's Avatar
Default For Those Running the Moroso RR Oil Pan.
I have tried to call Moroso Technical Support but keep getting a busy signal. Since I know there are others in here that have this pan I need to know when using the RR Pan for the 1.8/1.6L B series motors (part #20910) will the standard dipstick be sufficent when checking oil levels or is there a special dipstick that is needed to check oil levels?
Old Apr 17, 2006 | 08:28 AM
Circuit Star-29's Avatar
Default Re: For Those Running the Moroso RR Oil Pan. (ralphie14)
I can't imagine the use of a special dipstick being necessary unless stated otherwise.
OEM should be fine. Check their website in the FAQs section.
Old Apr 17, 2006 | 11:12 AM
Chris F's Avatar
Default Re: For Those Running the Moroso RR Oil Pan. (Circuit Star-29)
OEM dipstick works fine. You absolutely ought not to change the absolute level of oil compared to the oil pickup.
BTW-- on my B18C5 the tranny brace needs to be "massaged" to get it to fit. By "massaged" I mean chopped up with a sawzall. I think the other B's are different. But, the pan works great and I like the extra capacity and cooling and baffling.
-Chris
Old Apr 17, 2006 | 11:37 AM
rmcdaniels's Avatar
Default Re: For Those Running the Moroso RR Oil Pan. (Chris F)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris F &raquo;</TD></TR><TR><TD CLASS="quote">
-Chris
Are you using the new steel one or the old aluminum one? My steel RR pan is just like OEM on the outside except for the kickout.
P.S. - And I use the OEM dipstick, works fine.
Old Apr 17, 2006 | 03:04 PM
Lo-Buck EF's Avatar
im using the new steel one and the oem stick works fine.
Old Apr 17, 2006 | 05:34 PM
Chris F's Avatar
Default Re: For Those Running the Moroso RR Oil Pan. (rmcdaniels)
this one. 20910.
Looks OEM size, isn't OEM size. My 3" downpipe is also right up against it.
Old May 19, 2006 | 02:16 PM
GSRCRXsi's Avatar
quick question. is this pan (20910) for GSR/ITR or LS/B16? since it uses the stock pickup wouldnt it cause problems if you used the wrong pickup? which engine is this pan made for? does it matter?
only rason i ask is because of the difference of stock pans/pickups between b16/ls and gsr/itr
Old May 20, 2006 | 09:33 AM
Mr Hammond's Avatar
a/k/a Jomo
Default Re: For Those Running the Moroso RR Oil Pan. (GSRCRXsi)
I bought the 20910 pan from Moroso. Either got it from Jegs or Summit, can't remember. Looking at the instructions I got here, says it fits 1994-1998 Acura Integra with 1.8L VTEC and Non-VTEC. 5.5 Qt capacity, use stock Honda oil pan gasket, oil pump and oil pickup. I had no issues installing it on my USDM B18C1. JDM 4-1 clears no problem as well. I put in 5.5 Qts every time. Right on the upper mark. Stock dipstick. You don't want to change this as a reference point. Just because the pan holds 1-1.5 Qts more, just add that oil and you'll be back up on the dipstick. It makes sense if you just stop and think about it.
Old May 22, 2006 | 09:17 AM
rex_boy's Avatar
Default Re: For Those Running the Moroso RR Oil Pan. (Mr Hammond)
I had this on my B16 with no problems so it must fit both the B16A and B18C's
Old Sep 4, 2006 | 01:55 PM
Armaan's Avatar
Default Re: For Those Running the Moroso RR Oil Pan. (rex_boy)
Does the OEM windage tray work with this pan?
Old Sep 4, 2006 | 07:28 PM
Chris F's Avatar
Default Re: For Those Running the Moroso RR Oil Pan. (Armaan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Armaan &raquo;</TD></TR><TR><TD CLASS="quote">Does the OEM windage tray work with this pan? </TD></TR></TABLE>
On my ITR, yes it fits fine. Only thing that didn't fit was the tranny brace/flywheel splash shield/whatever that is.
Old Sep 4, 2006 | 09:07 PM
Armaan's Avatar
Thanks Chris. Did you modify the brace/splash guard? I guess it's an issue when using any pan other than Mugen/Spoon.
Old Sep 4, 2006 | 09:23 PM
Chris F's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Armaan &raquo;</TD></TR><TR><TD CLASS="quote">Thanks Chris. Did you modify the brace/splash guard? I guess it's an issue when using any pan other than Mugen/Spoon. </TD></TR></TABLE>
You know what? I don't remember why I didn't put it back on. I do remember hacking the **** out of it. But, I just left it off in the end.
Old Sep 6, 2006 | 03:59 AM
rallybird's Avatar
On an ITR, does this pan hang down lower than the OEM pan? Ie. is it closer to the ground, than the oe pan?
Old Sep 6, 2006 | 08:17 AM
ITRacer121's Avatar
can we get some pics of it installed? fitment? what you took off? and ground clearance?
do you guys think this mod was worth the money? that much better then a stock with baffels welded in?
Old Sep 7, 2006 | 10:48 AM
KIWI's Avatar
Default Re: (ITRacer121)
Absolutely a good move and well worth the money... We use Moroso pans on all of our 'B' Series engines. Great part, baffles work well. Use the stock dip stick and stay away from the Canton Oil Pans they are worst fitting pieces of crap I have seen!
Kiwi
Old Feb 18, 2007 | 08:30 AM
wilcoelskamp's Avatar
Default Re: (KIWI)
I would buy this Moroso 20910 oil pan to , but i read a few issues , but are there issues???
*If i read this topic i can use the OEM dipstick.
*I can't replace the splash guard any more , but is that the splash guard form the gearbox (Flywheel cover) or the splash guard for the underneed engine???
*But how is the ground clearance and can is stil use my aftermarket header??
Old Feb 18, 2007 | 09:22 AM
Lo-Buck EF's Avatar
no need to bump every 'moroso oil pan' thread. one will surfice.
Dat1BVtecN
Oct 11, 2008 03:47 PM
K20A2 5 lug EG
Aug 6, 2008 11:50 AM
Jugga
Apr 7, 2008 07:30 AM
RHDintegXsi
Jun 17, 2006 04:20 AM
jeremy.
Jan 29, 2004 01:13 PM
