Annoying idle
a vacum line thats missing from your manifold.or riped ect.its because it gets air but your tps sensor sais that the throtle is allthe way closed .so the ecu cuts your gasoline on and on.but ya. check all your vacumm hoses
if would check Idle air control valve (search) first clean that, next check for vacuum leaks by spraying carb cleaner around where intake mani meets the head it will start to idle normal once that is sprayed on meaning u have a vacuum leak, next try you fast idle thermal valve (search for fitv). it has to be one of those things
