?? problems with new suspension
Old Apr 16, 2006 | 09:13 PM
slow94civic's Avatar
Default ?? problems with new suspension
i have a 94 si and recently just purchased kyb agx's and k sport gt lowering springs. the problem is that the driver side is sitting about 1/2 to 3/4 of an inch lower than the passenger side. it is only in the front i have taken the whole suspension out and checked and double checked and can find nothing wrong i have even swapped the front springs(from driver to passenger) and nothing. i was reading about the k sport springs and they say they have a progresive spring rate.... has anyone had this same problem i need help thanks.
Old Apr 16, 2006 | 09:19 PM
professor poon's Avatar
aren't they adjustable?
Old Apr 16, 2006 | 09:24 PM
Default Re: (professor poon)
the kybs yes, dampening is not ride height
Old Apr 16, 2006 | 09:30 PM
Schrader's Avatar
Is there other visible problems other then the springs?
Old Apr 16, 2006 | 09:42 PM
ZipTieGUy's Avatar
just wait a bit for the springs to settle, they will never be perfect thoguh. thats why you get coil overs
Old Apr 16, 2006 | 09:45 PM
Default Re: (Schrader)
nope. i can live with the height difference but it rubs really bad in right turns. i have taken this suspension apart and checked everything, tire pressure, everything i can think of . im stumped.....
Old Apr 16, 2006 | 09:46 PM
Default Re: (ZipTieGuy)
i have a set of slip on coil overs but they are too harsh thats why i went with the springs.... should have just went with k sports full system. but regardless i need to fix it any info helps guys
Old Apr 16, 2006 | 10:32 PM
anyone
Old Apr 16, 2006 | 10:38 PM
VSM_EK's Avatar
From: In The Oregon Dunes, scaring little kids..., USA
Default Re: (slow94civic)
try to wait for them to settle if not take it back to where you bought them and ask whats up. or call the place where you ordered them
Old Apr 16, 2006 | 10:48 PM
Rayz_Si's Avatar
From: Land of the Hillbillies and Shotguns, Ontario, Canada
Default Re: (CGP-EJ8)
https://honda-tech.com/zerothread?id=1231318
LOL LOL Buddy I was the same as you when I just got my car lowered!! Same problem, and concerned the same way.
It is normal and nothing you can do about it, unless you have coilovres some people screw down the right side of the car lower to match the left side.
What is happenenin is your car already sits lower on the right, but when you lower it, you can notice it more that's all. Don't worry bro. The wieght of the engine is on the left side.
My girlfreind's 96' EX that's dropped 2" for more than 3 years still sits a little lower on the left side but it's better than my car cause my car was just dropped last year. Over time your springs will " work in" sag" or "settle in" as they call it and the difference should not be that noticiable after time. It's when you first do they drop you notice it immediatly.
Don't worry bro everything's alll good
Old Apr 17, 2006 | 06:40 AM
ok thanks guys that makes me feel better at least om not the only one....
tigerwing
Aug 2, 2010 12:22 PM
travail06
Honda Civic (2006 - 2015)
Jul 30, 2006 06:24 AM
92inprogress
May 19, 2005 08:41 AM
