ek suspenion on eg
my suggestion is you should do the whole suspensions, it will be easier for you trust me. on my 94 dx i put 99 si suspensions and brake rotors (front and back). it all started with the rear shocks cause my bushings and the bolts on my shocks got fused together. used to think that the rear shocks would fit. but i had 99 si shocks so form there i just replaced the entire suppension front and back.
front shocks yes, front forks no
rear shocks maybe... aftermarket shocks tend to come with washers to space out the lower mount. If not you can shave your EGs lower mount ot fit the EKs narrower shock mount.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by todahatch »</TD></TR><TR><TD CLASS="quote">well its tein basic and wondered if i would have to shave the bushings </TD></TR></TABLE>
fronts will fit, rears will either need you to change out the lca's or shave the bushings... I have Tein SS's for EK on my EG2
