decal removal
Old Apr 16, 2006 | 07:45 PM
Panda hatch's Avatar
Default decal removal
hi i was wondering whats the best way to remove decals off my civic. theres also one on my windshield and dashboard. thanks
Old Apr 16, 2006 | 07:48 PM
5lugSlug's Avatar
Default Re: decal removal (Alex804)
finger nail and rubbing alcohol - then clean the windows
Old Apr 16, 2006 | 07:53 PM
ef0cmacro's Avatar
Default Re: decal removal (EJacul8)
"goof-off" eats up adhesives well
u can also use
wd-40, rubbing alcohol, razor works good too
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">
i had to get decals off of work trucks before (company trucks), best technique we find is just using your finger nails. IMO better be careful when using goof off, i used it on my car to get off the civic decal before a paintjob and it was removing the clear off my paint... so you have to be careful, goof-off takes off eeeeverything if u aren't careful. </TD></TR></TABLE>
true, because goof off is in fact, a very weak "paint thinner" just be careful when applying
Modified by chewbakha at 9:44 PM 4/16/2006
Old Apr 16, 2006 | 08:24 PM
alpous's Avatar
Old Apr 16, 2006 | 10:46 PM
tsdenny's Avatar
hair dryer and finger nail
goo gone to clean up
Old Apr 16, 2006 | 10:53 PM
Rayz_Si's Avatar
From: Land of the Hillbillies and Shotguns, Ontario, Canada
Default Re: decal removal (void_accord)
On a very hot day make the sticker face the sun, it will get hot and soft enough and will peel of so easily, if there is any glue residue try windex, rubbing alcohal, or goo-gone.
Today I just peeled of stickers in the sun, what a breeze.
Old Apr 16, 2006 | 11:37 PM
EM199dcs's Avatar
peel it off doesnt matter day or night. but afterwards I would strongly advise you have goo-gone and use it. goo gone is the sh*t
Old Apr 17, 2006 | 12:12 AM
KoLRaNcH's Avatar
Default Re: decal removal (EM199dcs)
I used "goo gone" before on my old civic and it damaged my paint.
I found the best thing that works is wd40 and your finger, maybe a hair dryer(won't hurt).
Old Apr 17, 2006 | 05:39 AM
-Gary-'s Avatar
Default Re: decal removal (KoLRaNcH)
WD40 and patience.
Old Apr 17, 2006 | 09:57 AM
viahiptop's Avatar
Default Re: decal removal (scuzz)
Steam gun/cleaner FTW. Melts the glue so you can easily peel it off. Great for removing tint as well. Done it many times. Hope this helps
Old Apr 17, 2006 | 09:58 AM
db8gsr_teg's Avatar
goo-gone
Old Apr 17, 2006 | 10:27 AM
viper1984's Avatar
Heat gun/hair dryer. and plastic razor blade,But be careful not to burn out the hair dryerif you use one.
Old Apr 17, 2006 | 08:55 PM
nello a.'s Avatar
i used a hair dryer and my fingernail. denatured alcohol will take off the adhesive and your wax. make sure you re wax the area.
tearlessj
Paint and Body
11
Mar 5, 2008 10:40 AM
infinkc
Jan 27, 2003 03:34 PM
getfast
24
Nov 27, 2001 06:53 PM
urbanlegend21
Jun 19, 2001 10:36 PM
