88 civic trans with a d16y8 will it work>?
ok i have a 91 si ef hatch the original tranny went out so i picked up a 88 trans the stock 91 clutch does not fit on the 88 trans i bought a 88 clutch and it fits but now my question is will it fit on the single cam vtec d16y8 98 motor????????
You will have to get a 88 clutch for ANY motor you try to put it onto.
The 88 trans will bolt up the the 98 motor, for the 98 (if going into that car) is a hydro car.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beaneg6 »</TD></TR><TR><TD CLASS="quote">ok i have a 91 si ef hatch the original tranny went out so i picked up a 88 trans the stock 91 clutch does not fit on the 88 trans i bought a 88 clutch and it fits but now my question is will it fit on the single cam vtec d16y8 98 motor????????</TD></TR></TABLE>
Not to be an @$$, but dont you think after 1100+ posts you should know how to make it easier to understand?! Use some punctuation.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brg2nr »</TD></TR><TR><TD CLASS="quote">
Not to be an @$$, but dont you think after 1100+ posts you should know how to make it easier to understand?! Use some punctuation.</TD></TR></TABLE>
sorry i was in a hurry the guys car was in my front yard. . .problem solved swapped the clutch over to a 88 from a 91 and it worked fine,
sepheroth
Transmission & Drivetrain
Jul 29, 2014 08:41 AM
Davanca
Aug 12, 2003 05:45 AM
89SiB16a
Oct 30, 2002 04:02 PM
