type s decklid spoiler
Old Apr 16, 2006 | 06:30 PM
slowgd3's Avatar
Default type s decklid spoiler
does any1 know where i can get the type s decklid spoiler? my sis's types got hers jacked so know we need to find a new 1
Old Apr 17, 2006 | 01:02 AM
i0o0ll0o0i's Avatar
Default Re: type s decklid spoiler (xchooex)
What is the decklid spoiler? If you are referring to that thin strip of a spoiler that came on the hatch section of the 05-06 Type S's then I think you can find a replacement on Ebay, or at a store that sells OEM equipment.
How was it attached by the way? Bolted on, or double sided tape?
Old Apr 17, 2006 | 05:18 AM
TypeSKid's Avatar
just save yourself the trouble and buy a type r
Old Apr 17, 2006 | 04:22 PM
ssmdc2's Avatar
Default Re: type s decklid spoiler (i0o0ll0o0i)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by i0o0ll0o0i &raquo;</TD></TR><TR><TD CLASS="quote">What is the decklid spoiler? If you are referring to that thin strip of a spoiler that came on the hatch section of the 05-06 Type S's then I think you can find a replacement on Ebay, or at a store that sells OEM equipment.
How was it attached by the way? Bolted on, or double sided tape?</TD></TR></TABLE>
It has 2 10mm studs and something like 5 clips. I just picked up one for my 02 rsx-s on ebay for like 60$ and it's supposedly pulled off of a brand new car (2 miles or something). You can get some good deals sometimes. I going to try and mount it with out drilling holes, but I don't want it flying off at high speeds.
Old Apr 17, 2006 | 04:45 PM
slowgd3's Avatar
Default Re: type s decklid spoiler (ssmdc2)
it is held together by double sided tape
Old Apr 17, 2006 | 05:19 PM
ssmdc2's Avatar
I don't want to start a war here, but I am 100% sure there are bolts and clips. I have this wing in my possesion. There is foam and such underneath the wing too so as not to mar the paint.
Old Apr 17, 2006 | 06:58 PM
slowgd3's Avatar
o
Old Apr 18, 2006 | 07:31 PM
blackout9300's Avatar
I'm not sure what it would be worth but I have an 05 rsx-s that I've been looking to get the type-r spoiler not too crazy about the lip.
Old Apr 19, 2006 | 06:10 AM
The Tech-1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ssmdc2 &raquo;</TD></TR><TR><TD CLASS="quote">I don't want to start a war here, but I am 100% sure there are bolts and clips. I have this wing in my possesion. There is foam and such underneath the wing too so as not to mar the paint.</TD></TR></TABLE>
Exactly
Old Apr 19, 2006 | 01:51 PM
i0o0ll0o0i's Avatar
So does this mean when the spoiler is taken off there will be holes? So much for trying to go wingless
Old Apr 19, 2006 | 04:28 PM
ssmdc2's Avatar
I believe its like 7 holes, can't remember exactly. If you open your hatch and look underneath at the outer edges there is a black plastic plug. remove that and inside you should see a 10mm nut, remove those and then pull like hell to undo the clips and its off. Instead of pulling hard you might have to use a panel poper or remove the inside plastic to squeeze the clips with a needle nose pliers or something.
blazzer
Paint and Body
Sep 6, 2015 06:22 PM
boostedEBP
Dec 2, 2007 12:38 PM
Crackerballer
May 3, 2006 06:36 PM
CRX Si
Nov 17, 2002 03:46 AM
CRX Si
Nov 14, 2002 10:27 PM
