OBD0 -> OBD1 conversion
Old Apr 16, 2006 | 06:06 PM
baggelis's Avatar
Default OBD0 -> OBD1 conversion
I am doing the OBDO to OBDI conversion on my 91 CRX Si, the engine is a '99 D16Y8 (which as you all know is OBDII). My question is can I just put on the OBDI dizzy on the D16Y8 engine and run the P28 ECU and 4 wire O2 sensor or am I required to do something else?
Feedback greatly appreciated
Old Apr 16, 2006 | 06:11 PM
si0385.'s Avatar
almost positive the obd1 dizzy works on the y8 yead no problem
someone confirm please
Old Apr 16, 2006 | 06:40 PM
4potnick's Avatar
Default Re: (si0385.)
obd1 and obd2 dizzys work the same but have different mounting holes. obd0 & obd2 mount the same and obd1 are a little different but you can use it.
Old Apr 16, 2006 | 06:43 PM
Rywire's Avatar
Default Re: (4potnick)
with a y8 head, use a y8 dizzy, or a td41u dizzy. The td41 is from a nonvtec EG civic
Old Apr 16, 2006 | 06:44 PM
4potnick's Avatar
Default Re: (droppedcrxsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by droppedcrxsi &raquo;</TD></TR><TR><TD CLASS="quote">with a y8 head, use a y8 dizzy, or a td41u dizzy. The td41 is from a nonvtec EG civic</TD></TR></TABLE>intersting. all holes line up?
Old Apr 16, 2006 | 06:46 PM
dr_latino999's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4potnick &raquo;</TD></TR><TR><TD CLASS="quote">intersting. all holes line up?</TD></TR></TABLE> Yup, the TD41U uses the same mounting holes as the D16A6 distributor, and I remember people adding the Y8 Head and staying OBD-0 used the A6. Also Nick, I got your PM today, my condolences.
Old Apr 17, 2006 | 09:15 AM
baggelis's Avatar
So I cannot just slap on the OBDI on the Y8 head?
Old Apr 17, 2006 | 12:04 PM
lightcrx's Avatar
use the obd2 dizzy its works the same as the obd1 but with a different connector
-joseph
Old Apr 18, 2006 | 09:18 PM
Rywire's Avatar
Default Re: (lightcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lightcrx &raquo;</TD></TR><TR><TD CLASS="quote">use the obd2 dizzy its works the same as the obd1 but with a different connector
-joseph</TD></TR></TABLE>
Correct, read above, we just said this... or the td41
Old Apr 18, 2006 | 11:47 PM
jdmcrx90's Avatar
yes everthing will work with dizzy, but im not sure about the knock sensor. I don't think it should matter because a p28 won't be looking for knock sensor.
Old Apr 19, 2006 | 12:53 AM
Rywire's Avatar
Default Re: (jdmcrx90)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmcrx90 &raquo;</TD></TR><TR><TD CLASS="quote"> don't think it should matter because a p28 won't be looking for knock sensor. </TD></TR></TABLE>
tru
Old Apr 19, 2006 | 12:07 PM
lightcrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by droppedcrxsi &raquo;</TD></TR><TR><TD CLASS="quote">Correct, read above, we just said this... or the td41</TD></TR></TABLE>
i figured he overlooked it so i had to repost, happens to me all the time
inh
Jul 30, 2006 06:38 PM
NACvicSi
Nov 18, 2005 07:50 PM
vegaskurt
May 14, 2005 10:17 PM
srv3fender
12
Mar 30, 2005 06:40 PM
mengy007
Jan 25, 2005 02:46 PM
