How do I remove valvestem seals from B16A2 - SEARCHED
Old Apr 16, 2006 | 05:40 PM
drumminforev's Avatar
Default How do I remove valvestem seals from B16A2 - SEARCHED
2000 si b16a2. Need to remove my valvestem seals by removing the head.
If you can direct me to webpages, previous posts, or type new info, great.
Old Apr 16, 2006 | 05:43 PM
fmrprojects's Avatar
Default Re: How do I remove valvestem seals from B16A2 - SEARCHED (drumminforev)
first you need to remove the springs and retainers using a valve spring compressor. then just use some pliers to take them off. to put them back on just get a socket that fits over them , and tap it on
Old Apr 16, 2006 | 05:52 PM
Alright, do you recommend a manual to get, ie which brand, for head removal and seal installation.
Old Apr 16, 2006 | 07:11 PM
posite's Avatar
helms
Old Apr 19, 2006 | 09:30 AM
Default Re: (posite)
Which is better, helms or chilton
Old Apr 19, 2006 | 09:38 AM
schardbody's Avatar
no need to remove the head if you have a compressed air source.
Old Apr 19, 2006 | 09:39 AM
Default Re: (schardbody)
I have heard that before, but NO ONE will post detailed instructions on how to do this properly. If you know, please type, if you know a source of info, direct me to it.
Old Apr 19, 2006 | 09:53 AM
schardbody's Avatar
you just use an adapter that screws into the spark plug hole, open the valve so you have air pressure in the cylinder to keep the valve from dropping. once you have pressure in the cylinder you can remove the valvesprings for that cylinder and change the seals, reinstall springs and do next cylinder.
Old Apr 19, 2006 | 10:17 AM
So the seal is on the top of the valve, only covered by the spring. And how will i know if i have sufficent pressur on the cylinder. and how would i know if each particular valve is open
Old Apr 19, 2006 | 10:26 AM
lodo1's Avatar
Default Re: (drumminforev)
pretty much if your familiar with doing a leak down test on the car, you can just leakdown test each cylinder, and that will keep the air in the cylinder and keep the valve from dropping in.
Old Apr 19, 2006 | 10:34 AM
schardbody's Avatar
just use atleast 100-125psi straight to it, dont shut the air off once its aired up or anything. hook up the air leave it on, remove valve spring. you need to put the cylinder at TDC to take any pressure off the valves from the cam. you can tell when all are closed in each particular cylinder.
Old Apr 20, 2006 | 07:37 AM
sweet. again which is better, helms or chiltons
Old Apr 20, 2006 | 07:53 AM
schardbody's Avatar
i prefer helms, but they are basically the same, just always had helms avail.
Sleeping4drLS
14
Sep 11, 2009 02:44 PM
sean2000gt
May 26, 2009 03:33 PM
averyvm
Oct 23, 2006 05:35 PM
RACEPAK
11
Dec 11, 2005 03:03 PM
wing
Mar 28, 2005 01:37 PM
