my car is running rich.
Old Apr 16, 2006 | 02:32 PM
fbw2003's Avatar
Default my car is running rich.
ok heres the prob i did a mpfi swap in my std. i rebuilt a d16a6 engine and tranny and did the swap. every thing runs good but it is running really rich and im only getting about 15 miles to the gallon. i was justwondering if any one could help.
Old Apr 16, 2006 | 02:46 PM
JKingCivicSi's Avatar
Any CEL?
Old Apr 16, 2006 | 03:04 PM
fbw2003's Avatar
Default Re: (JKingCivicSi)
it was throwing a o2 sensor code but i got that fixed i think it not throwing it anymore.
Modified by fbw2003 at 8:21 PM 4/16/2006
Old Apr 16, 2006 | 07:22 PM
fbw2003's Avatar
Default Re: (fbw2003)
come on someone i need some help
Old Apr 16, 2006 | 07:27 PM
jdmazm's Avatar
check two things, take a voltmeter to the o2 sensor, the voltage should jump up and down. Next check out your IAT sensor on your intake manifold, this caused my car to run a bit rich.
it can be something stupid such as spark plugs, wires, dizzy cap & rotor or dirty *** injectors.
and check for codes
Old Apr 16, 2006 | 08:56 PM
firebane's Avatar
Default Re: (jdmazm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmazm &raquo;</TD></TR><TR><TD CLASS="quote">check two things, take a voltmeter to the o2 sensor, the voltage should jump up and down. Next check out your IAT sensor on your intake manifold, this caused my car to run a bit rich.
and check for codes</TD></TR></TABLE>
Just changed my plugs and wire and put some Lucas Injector cleaner into my last tank of gas and my mileage has increased by a lot. I'll be planning on doing cap and rotor next.
Old Apr 19, 2006 | 01:20 AM
fbw2003's Avatar
Default Re: (firebane)
thanks ill try and see what happens
Old Apr 19, 2006 | 01:40 AM
STREETWERKZ's Avatar
any chance your mileage went down because your foot got heavier?
Old Apr 19, 2006 | 08:12 PM
fbw2003's Avatar
Default Re: (STREETWERKZ)
no i drive 70 on the highway getting that kind of mileage.
Old Apr 20, 2006 | 10:30 AM
fbw2003's Avatar
bumb for some moe help
Old Apr 20, 2006 | 05:03 PM
fbw2003's Avatar
still need some help
Dachdu 92
Sep 26, 2010 10:25 AM
Shonn
Oct 16, 2006 04:29 AM
98IntegraLSNonVtec
Jul 31, 2006 01:46 PM
96lewd
Jan 23, 2005 08:44 PM
