Pressure in tank
This morning I went to the store and when I came out my car wouldn't start. I've had this problem before, but this is the first time since the swap. I noticed that the CEL would not go off when you turn the car to the on position after the fuel system is supposed to prime. I also noticed that you couldn't hear the fuel system prime either. Also when I fill up with fuel I would notice that there was lots of pressure when I would remove the gas cap. I pulled the negative cable from the battery to reset the ecu and it started right up. Please let me know what you think
I just thought it was weird when it started bubbling out the filler neck, thats all. Also when it wouldn't start I couldn't hear the fuel pump prime so I didn't know if that had something to do with it.
MHDesigns
24
Oct 15, 2009 03:51 PM
