My Stock DOHC ZC On 15lbs
This was done on 93 octane pump gas with a stock motor. My tuner and I were talking one night and figured that the compression on the zc is lower then the b16 and Gsr motors so we figured we could tune the motor to 15lbs with a real solid tune. We ended up upping the boost from 10lbs were I made 238whp and 181wtq to 15lbs where I made 278whp and 230wtq. These number are from a dynojet machine. By looking at the graph the power improved everywhere. By 6k I had made a 60whp gain!! Once again I would like to say tuning is key! O yea im running a Td06 17c turbo. My A/F is 11.8-11.5 through out the band.Setup was tuned on Crome pro by Huy Tran of Inline Racing here in Houston, Texas.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LurkerS8 »</TD></TR><TR><TD CLASS="quote">10lbs were I made 238whp and 181wtq .</TD></TR></TABLE>
Thats what I'm shooting for
graph looks good
DOHC ZC T
graph looks good
DOHC ZC T
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LurkerS8 »</TD></TR><TR><TD CLASS="quote">Pretty much your looking at 3500 for the whole turbo setup and tune.</TD></TR></TABLE>
damn, spendy. so pretty much, if u have a real good tune, you can run as much boost as you want on a stock block? cuz i thought you could only do 8 pounds on a stock setup, but you proved me wrong.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SVOboy »</TD></TR><TR><TD CLASS="quote">Tuning doesn't equal unlimited boost, but it's important to have it regardless.</TD></TR></TABLE>
Yea tuning won't let you boost what ever you want, but it makes it safer to run high amounts of boost. Im not really worried about the rods because I compared the rods of a zc and a Ls and the rods on the zc are thicker in everyway. What I am worried about blowing are the rings on the pistons. Well see how it goes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bjorn20 »</TD></TR><TR><TD CLASS="quote">nicely done, another 200+ whp stock d series</TD></TR></TABLE>
Stock doesn't equate to a DOHC ZC with a turbo slapped on it running 15lbs.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Driven »</TD></TR><TR><TD CLASS="quote">
Stock doesn't equate to a DOHC ZC with a turbo slapped on it running 15lbs. </TD></TR></TABLE>
Lol.
Lol.
Wow!
Those are some numbers!
Damn, I knew the DOHC ZC had beffy internals, but I didn't think it would make that much power on only 15psi. Those are stock LS number right there.
Nice work
Nice work
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iheartlittlebear »</TD></TR><TR><TD CLASS="quote">that is 3500 including the motor im hoping right</TD></TR></TABLE>
No but it includes 2.5in piping, stainless steel log manifold, 3inch pie cut side exit, dump tube, wastegate, intercooler, new td06 17c turbo, 450cc injectors, 255 fuel pump, all couplers, all stainless T-clamps, and crome tune.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek HATCHIE »</TD></TR><TR><TD CLASS="quote">dang 15lbs on stock...</TD></TR></TABLE>
Yea well see how it holds. I had about 10 races last night and it had no bad signs. Compression is still perfect. I accidentlly over reved it one time to 8k
hey boss....do you think a sleeved and built d single vtec cam je rods and piston, w/ ported and polished head along with turbo camshaft from crowler, and crowler springs and retainers would hold 20 psi ?? currently at 8.56 psi crome chipped also with 259 horses. dont know how i got that high with just 8.56psi but the turbo is from greddy and my heads ported and polished with matching intake manifold and exhaust also...but yeah, do you think my turbo will hold 20psi? its a tdo4 14g from greddy. they said it can do 1.9 bars easily...i posted today but no one has responded to my add...maybe you could help.. thanks
lol....j/k man good numbers
