Suspension & Brakes Theory, alignment, spring rates....
are you lowered?post your specs and tire wear pattern
Old Apr 15, 2006 | 09:26 PM
$amGD3's Avatar
Swaggylicious
Default are you lowered?post your specs and tire wear pattern
I just want to see,what it looks like out there because i'm debating if i should invest in a camber kit or not..
...so please post the approx. inches that you are dropped,degree of camber,tire wear pattern,
as for my self i think I'm dropped around 3- 3 1/2" inches,probably close to -3 degrees?tire wear pattern...idk yet i just got these new wheels/tires
..thanks
Old Apr 15, 2006 | 11:21 PM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: are you lowered?post your specs and tire wear pattern (sam21)
3.5" is pretty low. I'm lowered 3" on 205/40/16 (and that's scary sometimes). My tread-wear is fine. My last set of BFG Euro TAs (same size) lasted at least 45,000 miles. It could have been more, but I don't remember exactly when I got my rims...
You shouldn't need a camber kit (I don't have any). Just make sure to get an alignment if you haven't already. The lowering causes static toe settings to change pretty drastically. Bad toe setting will cause the cambered edge of your tires to wear rapidly since they are now scrubbing the ground. If toe has truly been zeroed out, you should not experience any camber wear. After all, some sharp corners easily move the normal wear back to the outside shoulder...
mykeerocks
Honda Civic (2001 - 2005)
Mar 15, 2008 08:12 AM
JRizEJ6
30
Dec 1, 2006 08:33 PM
alex_s817
Mar 25, 2006 09:43 AM
vsm dc4
Suspension & Brakes
13
Feb 7, 2005 04:37 AM
silverCRXTC
Mar 21, 2004 04:47 AM
