spray on a gsr??
Old Apr 15, 2006 | 09:08 PM
datnigabluberry's Avatar
Default spray on a gsr??
im thinkin bout sprayin on my gsr, if i do it will be stock motor except itr pistons. how much will it handle?
Old Apr 16, 2006 | 04:07 PM
sc4dr's Avatar
Default Re: spray on a gsr?? (datnigabluberry)
75 to 100 shot wet.
Old Apr 17, 2006 | 08:17 AM
Phase Change Racing's Avatar
You should be able to run up to 100HP or so without any problems if you have adequate fuel supply and a good tune. 75HP i'd be comfortable running on there all day every day. You are lucky, those GSR intakes are a piece of cake to install direct port systems on, im doing one as we speak.
Old Apr 18, 2006 | 06:10 AM
Default Re: spray on a gsr?? (Phase Change Racing)
im gonna be runnin the skunk 2 pro series intake manifold. should i run direct port?
Old Apr 18, 2006 | 08:34 AM
raiden571's Avatar
yup. direct port isnt to bad of an install as stated before, just have to have patience and good tools. i just dont under stand how you tune a nitrous setup being that u usually dont use it all the time
Old Apr 18, 2006 | 09:06 AM
Soccerking3000's Avatar
Default Re: (raiden571)
a nitrous map, seperate fuel pump and lines just for the nitrous and tuning the fuel pressure and pills will do it too
Old Apr 18, 2006 | 09:13 AM
Ive not seen the Skunk 2 setup for the GSR's but id think it would be easy. The layout of the GSR intake is what makes them so easy to plumb, there is just a lot of realestate to work with heh heh. After doing a coule b16 intalls, everything seems easy lol.
lazyxmofo
May 12, 2008 03:02 AM
oneslowsohc
Feb 16, 2005 06:48 PM
mischiefinnovations
Sep 19, 2004 09:45 PM
GSRontheBottle
Dec 20, 2002 03:28 PM
GSRBoy
Aug 18, 2002 08:54 PM
