spray on a gsr??
You should be able to run up to 100HP or so without any problems if you have adequate fuel supply and a good tune. 75HP i'd be comfortable running on there all day every day. You are lucky, those GSR intakes are a piece of cake to install direct port systems on, im doing one as we speak.
yup. direct port isnt to bad of an install as stated before, just have to have patience and good tools. i just dont under stand how you tune a nitrous setup being that u usually dont use it all the time
Ive not seen the Skunk 2 setup for the GSR's but id think it would be easy. The layout of the GSR intake is what makes them so easy to plumb, there is just a lot of realestate to work with heh heh. After doing a coule b16 intalls, everything seems easy lol.
oneslowsohc
Feb 16, 2005 06:48 PM
