TIming belt service..car does not feel the same
Old Apr 15, 2006 | 08:35 PM
Mike VR6's Avatar
Default TIming belt service..car does not feel the same
So I have a 97 Honda Accord, with about 100K, so I got the timing belt service done last week. Replaced parts were: Timing belt, water pump, balance shaft belt, valve cover gasket, timing cover seal, oil pump seal, cam shaft seal, and a couple external belts.
Now, prior to this service...the car ran extremely smoothly. Now...while accelerating at lower speeds (say 5-30mph) I am noticing much more vibration in the drivetrain, and overall a deeper sound. Its a fine vibration, but it can be heard and felt through the pedals.
Any ideas of what this could be? SOmething to be worried about?
Old Apr 15, 2006 | 08:45 PM
accord-pro's Avatar
Default Re: TIming belt service..car does not feel the same (Mike VR6)
take car back and tell them the situation
have them double chk the work they did ,,
make sure they got the balancer shafts aligned properly..
make sure they tighten the upper left .. motor mount ,
Old Apr 15, 2006 | 08:49 PM
Ross 2.0's Avatar
In a Junkyard near you.
Default Re: TIming belt service..car does not feel the same (accord-pro)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accord-pro &raquo;</TD></TR><TR><TD CLASS="quote">
make sure they got the balancer shafts aligned properly</TD></TR></TABLE>
I would narrow it down to this. It's very easy to get one 180 degrees out. You will definately notice a vibration difference then. But no need to fear any damage. It's only there for your comfort (not a vital engine part). Heck a lot of people just take the shafts out and put a block off plate in if they plan to use the car for a race application.
But definately take it back and have it fixed.
Old Apr 16, 2006 | 10:48 AM
Mike VR6's Avatar
Default Re: TIming belt service..car does not feel the same (MooGoCow3)
I do plan to take it back. The other thing that I noticed was that it seemed like the car was almost geared lower. For example, if I am cruising at 70mph, and let off the gas, the engine braking effect is much more pronounced. The car is an automatic, and ususally the engine braking on this car wasn't that pronounced.
Old Jun 21, 2006 | 11:48 AM
RiceKillinSI's Avatar
i had the same problem with a 99 prelude i used to have .
bump for an update.
Old Jun 21, 2006 | 02:10 PM
momstaxi's Avatar
Default Re: TIming belt service..car does not feel the same (RiceKillinSI)
yes, sounds like a balance shaft issue..
Old Jun 21, 2006 | 02:17 PM
Ross 2.0's Avatar
notice the date of the original thread
Old Jun 21, 2006 | 02:19 PM
momstaxi's Avatar
Default Re: (MooGoCow3)
oops
Old Jun 21, 2006 | 02:22 PM
Ross 2.0's Avatar
it's all good. Just trying to keep the new advice down. I think the OP is long gone from HT.
chandlorexia
Oct 12, 2012 06:40 AM
chandlorexia
Engine Management and Tuning
Oct 11, 2012 10:44 AM
gamblezhang
Mar 26, 2006 08:06 AM
ninerpilot
Aug 16, 2005 07:44 AM
blue32
Jun 1, 2005 02:10 PM
