omni power rear lca's, problems? failures? other issues?
Old Apr 15, 2006 | 07:54 PM
snakepirates's Avatar
Default omni power rear lca's, problems? failures? other issues?
Just wondering if anyones had any problems with these after using them for a while.
I did a search but most people just talk about how the looks.
The only reason I'm considering them is to mount a rear sway bar on my eg hatch. I don't care about the looks of them (I'm probably painting them black when I get them). After pricing out used integra lca's with new poly bushings it works out to around the same as the price for the omni's.
Thanks in advance.
Old Apr 16, 2006 | 03:14 AM
BlueIntegraBoy's Avatar
Default Re: omni power rear lca's, problems? failures? other issues? (snakepirates)
Just get the Omnis. I haven't heard anything bad about them. I ordered a set to mount an ITR rear sway, but haven't had time to put them in yet. KTeller sells the LCAs for $100 shipped and comes with a cool D-Sport calendar with hot import models
Old Apr 16, 2006 | 06:01 AM
lil'ek's Avatar
Default Re: omni power rear lca's, problems? failures? other issues? (BlueIntegraBoy)
i've had mine for about a year with no complaints. but when i got an alignment a few weeks ago, i noticed that the sway bar bushings where worn and look like they should be replaced.
Old Apr 16, 2006 | 06:35 AM
MugenHonda's Avatar
From: With my POS D15B2, Whereever whenever, United States
Default Re: omni power rear lca's, problems? failures? other issues? (lil'ek)
my friend has them
it's all good except the bushing
the bushing is cheap and won't last
Old Apr 16, 2006 | 06:55 PM
Default Re: omni power rear lca's, problems? failures? other issues? (MugenHonda)
Thanks for the replies. Anyone else have problems with the bushings in the actual lca's themselves? I did a search but no one mentioned the bushing problem.
Old Apr 16, 2006 | 07:29 PM
kaiba's Avatar
All the aftermarket lca look like that all have the same bushing except Function7. They use poly.
sixteenfeet
Suspension & Brakes
17
Mar 20, 2018 02:17 PM
philosofy1
Suspension & Brakes
May 10, 2005 03:59 PM
opeth13
Jun 2, 2004 05:46 AM
clm
10
Aug 23, 2003 01:35 PM
viprcr1
Aug 16, 2003 04:58 PM
