Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Roll Cage Question.
Old Apr 15, 2006 | 06:07 PM
x2gold's Avatar
Default Roll Cage Question.
Hey guys, just doing some fitment of my cage into my EG hatch. Just wondering if the main hoop has to be square, or 90 degrees with the floor. I've seen a lot of pictures that show the main hoop titled slightly back ( base closer to the front than the top). Is there any rule or advantage to this, or is this incorrect. Thanks. Looking to SCCA, nothing to serious, but still want it to be correct. Thanks again.
Old Apr 15, 2006 | 06:25 PM
x2gold's Avatar
Default Re: Roll Cage Question. (x2gold)
cage is weld in / universal type 8 pt. with pre-bent main hoop
Old Apr 15, 2006 | 06:27 PM
dohcdelsol's Avatar
i dunno bout rules and such, but i have a S&W cage and it says to line up the main hoop 90 degrees to the floor
Old Apr 15, 2006 | 06:33 PM
x2gold's Avatar
Default Re: Roll Cage Question. (dohcdelsol)
ok..my instructions were general and they just said line it up with the pillar ( I assumed 90 degrees ).
Old Apr 15, 2006 | 06:39 PM
prkiller's Avatar
Hmm, don't think I would be to crazy about a pre bent "universal" cage in my race car. Details?
If you gonna go through with all the money and pain of putting a cage in, fitment should be of prime importance!
Old Apr 18, 2006 | 06:11 AM
Solo1B16Hatch's Avatar
Default Re: Roll Cage Question. (prkiller)
mine is 90 deg and in line with the b-pillars
Old Apr 18, 2006 | 07:47 AM
Crazydave's Avatar
Default Re: Roll Cage Question. (Solo1B16Hatch)
check the rule book of the organization in which you will be racing, they have very specific rules regaring the cage construction.
http://www.scca.org/_FileLibrary/File/GCR2006.pdf
http://www.nasaproracing.com/rules/ccr.pdf
Old Apr 18, 2006 | 09:10 AM
CagedRuss's Avatar
Main hoop can be laid back a bit, check your National or regional rules to see if the main hoop and a maximum angle. I try not to lay it back no more than 10-15 degrees. Line it up with the B-pillars to the same angle, looks a lot better when it aligned. Keep in mind to keep the main hoop within the rule parameters for clearance.
Old Apr 18, 2006 | 09:38 AM
david@didrace.com's Avatar
I always make the main hoop perpendicular to the frame of the car. Doing it slanted back is just for looks.
Plus it's much much easier to bend up and notch bars when say the two parallel Nascar bars will be of the exact same dimensions.
EJ SIR
Jun 8, 2011 12:13 PM
EJ SIR
Jun 8, 2011 10:58 AM
Quik Chris
Jan 24, 2006 04:41 PM
6ghatch
25
Dec 23, 2003 10:58 PM
