wire up neutral safety switch?
Old Apr 15, 2006 | 05:19 PM
go2sleep's Avatar
Default wire up neutral safety switch?
i've searched and nothing come up exactly on wiring (just bypassing and etc) up a neutral safety switch. i had and auto and converted to manual.
i dont have the harness from the auto shifter anymore, and i want to wire up the neutral safety switch (need to press on clutch in order to start). any quick how-to would be great.
closes i came was this thread https://honda-tech.com/zerothread?id=1337459
Old Apr 16, 2006 | 09:43 AM
go2sleep's Avatar
Default Re: wire up neutral safety switch? (go2sleep)
up
Old Apr 16, 2006 | 05:23 PM
confusatron's Avatar
I didn't wire mine up, I just spliced those two fat wires together under the ashtray. Only problems I ever had was when I've had work done at a couple repair shops. I always had parked the car in neutral with the ebrake up. Start the car, let out the brake, get in gear and go. Well I guess that's not the normal way to do it, because the techs at the service shop always leave the car in 1st gear and then shut it off. So the first couple times I picked up the car from the shop, I'd start it up and it would lurch forward hard and fast. Scared the expletive out of me. So that's the only warning I would give you with this. Other than that it's perfectly fine to just splice those wires together.
If you want to wire it up though there's a tutorial somewhere on Hondaswap.com
Mikal92
Audio / Security / Video
Mar 17, 2009 04:07 PM
bpr0422
Aug 22, 2006 10:59 AM
jarel
Dec 16, 2003 02:01 PM
jarel
Dec 16, 2003 11:01 AM
raene
Aug 1, 2001 07:21 PM
