Apex'i Auto Timer for NA or Turbo NIB $85
Old Apr 15, 2006 | 05:18 PM
Fu_kJDM's Avatar
Default Apex'i Auto Timer for NA or Turbo NIB $85
Looks exactly like the one pictured above. New in box.
$85 picked up or shipped
Description:
The A'PEX Auto Timer allows the vehicle to idle for a present amount of time after the ignition key has been removed. This prevents hot oil in the engine from "coking" (solidifying) in the lines or center section of the turbo. Proper cool down is essential for a healthy engine. The Auto Timer stand as a technological marvel. The pen shaped, compact size makes the Auto Timer on of the smallest turbo timers on the market. This allows a clean and stylish installation virtually anywhere inside the car. The unique multi angle joystick button allows easy navigation through the many feature menus. Upgraded in every way from the previous model, the new Auto Timer can automatically determine the necessary amount of idle time. A Manual Mode allows the user to preset desired idling times from 0 sec. - 10 minutes in 16 increments. By inputting O2 sensor voltage, the Timer can also display theoretical air fuel ratio. Since the Auto Timer uses the factory O2 sensor which is primarily designed for emissions, the readings may not be as accurate as racing air fuel ratio monitors, but readings are very close. The Timer can also display critical data such as O2 sensor voltage and Battery Voltage.
714-6579190
Old Apr 16, 2006 | 08:16 AM
Fu_kJDM's Avatar
Default Re: Apex'i Auto Timer for NA or Turbo NIB $85 (Fu_kJDM)
Old Apr 17, 2006 | 01:22 PM
Fu_kJDM's Avatar
,n,,m hftdry76574534667utyhdrfrrgbvcbgh
Old Apr 17, 2006 | 11:41 PM
CivicFreak's Avatar
bumpity up up and away
froggy123
Feb 19, 2013 04:53 AM
panama_b18c1
May 2, 2007 03:37 PM
99B16Si
Jul 20, 2004 07:14 PM
Sh4rky
Mar 14, 2004 02:40 PM
B2FiNiTY
Oct 22, 2003 12:00 PM
