sticking caliper
I just installed gsr front brakes on my eg. Now the left pad is rubbing against the rotor and making a squeeking noise. Is there a way to adjust the distance between the pad and rotor?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jbscivichb92 »</TD></TR><TR><TD CLASS="quote">should I buy some of that stop squeak stuff?</TD></TR></TABLE>
if u do that..it might make the squeak go away..but the problem could still be there (what ever it is) and it could get worse..and 1 day..you wont be able to stop ..so figure out what it is first..
wait, do you mean the calipers are too close, or it's stickign? because in the post u said it's too close so it's rubbing, but the title said it's sticking
If it's sticking you need a new caliper if you can't resolve it with some lube...
If it's too close....I don't know what to do..I've never experienced that kinda problem..
Yeah I'm a bit confused if u mean the caliper's too small for the rotor it's on, or it's sticking..
If you put some lube or grease in the moving parts of the caliper and it still sticks, it's time for a new caliper..if it's too small, it's time for an adjustment (if that's even possible) or a part change..
alphalanos
14
Sep 8, 2008 04:07 AM
slow_rex_will
41
Sep 7, 2005 04:16 PM
