some can gives a solution?
#4 = Crankshaft position sensor (no signal) or intermittent interruption
#8 = Camshaft position sensor (no signal) or intermittent interruption
If the engine is running fine, I would re-set the light, and see if it comes back. (intermittent interruption)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nels6969on »</TD></TR><TR><TD CLASS="quote">I have a code from my honda accord 1993, 187 millages.
it flashed fourtimes then paused then flashed eight times.
you are talking about the ABS code correct?? 4-8 is for the left rear wheel sensor..
do a visual chk make sure all is ok,, ......if ok get a multimeter, unplug the wheel sensor and chk resistance it should be 1000-1600 ohms .. if resistance is ok,,
chk each sensor wire for continuity to ground,,, if there is continuity you got a wire shorted to ground or a bad wheel sensor
try this and post the results..
