what should i do before i take it to honda?
Old Apr 15, 2006 | 08:42 AM
cyang08's Avatar
Default what should i do before i take it to honda?
well i give up. i have done everything. my engine idles up and down when cold and when it warms up its a little better but not to how i want it. i done everything. check cleaned and replaced iacv, cleaned the whole TB, i removed the fast idle thing under my tb and cleaned that *****. looked for leak in vacum lines, nothing seems to help and no one i know, knows how to fix it. im geting pissed. taking it to honda is my last option but i know its gona cost alot. so you guys think they can figure it out? almost everyone with a honda i know has the same problem, but no one knows how to fix it. oh well if worst comes to worst maybe ill just try switching the whole intake manifold.
Old Apr 15, 2006 | 08:49 AM
imm0rt41's Avatar
How much does the idle fluctuate by? It could be a bad map sensor I guess. My friend had a similar problem, but we never got to try the new map sensor since he blew the engine on the way back from getting it =P
Old Apr 15, 2006 | 08:57 AM
SOHCEK-Turbo's Avatar
Default Re: (imm0rt41)
iat
Old Apr 15, 2006 | 09:04 AM
Brick Top's Avatar
try new TB and manifold gaskets. make sure all the bolts are equally tight. did u tighten the valve inside the fast idle thingy? bleed ur coolant system, a bubble in your IACV could cause that.
Old Apr 15, 2006 | 09:08 AM
swifty4u's Avatar
Default Re: (brick top)
Blah my car has the cure of the surging idle too.
Old Apr 15, 2006 | 09:15 AM
cyang08's Avatar
how do you bleed the coolant so there is no bubbles?? i know how to flush the coolant but not so sure if bleeding it is the same. and how do you tighten the valve inside the fast idle thermo valve? i put in new gaskets already but no help. my Tb is fine i am 100% sure of that. everything is nice and clean i dont know why it wont work right????
Old Apr 15, 2006 | 09:27 AM
EsQueue's Avatar
Default Re: (cyang08)
I had the exact problem with my h22 but fixed it from instructions online. Sorry but I forgot the name of the part I retightened and the search is down. I know that this parts allows air to bypass the throttle plates when it is cold. It's a little hole in the throttle body.
I had to take apart a little assembly and tighten a loose plastic piece.
Old Apr 15, 2006 | 09:28 AM
Brick Top's Avatar
there is a small valve to bleed the coolant. this needs to be open when filling your engine with coolant. i think u can still bleed it even though its full. what motor is in your car? so i can tell u where its at.
inside the fast idle, the is a big white valve with a long opening for a flathead. turn it to your right to tighten it. tighten it all the way down but don't torque on it.
Old Apr 15, 2006 | 12:33 PM
SkeeRX's Avatar
check the throttle body and itake mani gaskets with carb cleaner.. then check your map sensor wires and make sure it's plugged up correctly...
dfjr0926
Mar 10, 2011 05:16 PM
818blue818
Jan 6, 2009 02:59 PM
chrism
Jun 22, 2008 11:53 AM
FERIOkid
Nov 11, 2006 04:07 PM
supergreenNA1
Jul 23, 2002 03:27 PM
