oil pump/water pump
Old Apr 15, 2006 | 07:49 AM
hbyrd8701's Avatar
Default oil pump/water pump
i have a 99 b18b1 that in my storages. is it true that the96 on up b18b1,b18c1,b18c5share the same oil and water pump. also do the b16 also share the same pumps.
Old Apr 15, 2006 | 07:51 AM
Blue Hybrid's Avatar
Default Re: oil pump/water pump (hbyrd8701)
i know that all b series share the same oil pump. but i know that between the b16 and the b18c the water pumps can be interchanged but the gsr has one more tooth so the belt is longer. the b16 has 21 teeth on the pulley where the gsr has 22
Old Apr 15, 2006 | 08:00 AM
hbyrd8701's Avatar
Default Re: oil pump/water pump (gold EF)
i thought 90-95 ls has 19 teeth pulley and 92-95 gsr has 22 teeth pulley but 96 on up ( i dont know) that all b18 use the same pump.
Old Apr 15, 2006 | 08:04 AM
ok so you answerd your own question
Old Apr 15, 2006 | 08:19 AM
hbyrd8701's Avatar
yea.............i kinda did answer my on queston but i just want to make sure because a few months ago somebody posted and said that the 96 and up honda went ahead and used the same pumps in all the b series. i dont know if thus guy was lying or not.
1992db2
Jul 7, 2009 06:00 PM
SpoolnG2
Apr 1, 2008 06:15 PM
pokmijn
Oct 31, 2007 02:33 PM
Malgerus
Jan 11, 2003 04:33 AM
BoostinDC2
Jan 17, 2002 12:34 PM
