is my LSD busted?
Old Apr 15, 2006 | 07:35 AM
See Are X's Avatar
Default is my LSD busted?
with the front wheels off the ground, and the transmission in 1st, arent both wheels supposed to move in the same direction when you spin one wheel? Also, I let the car run in 1st gear with the wheels off the ground, both wheels were spinning forward, but I was able to stop one wheel with my hand. Is that normal?
Old Apr 15, 2006 | 09:47 AM
non-VTEC's Avatar
Default Re: is my LSD busted? (See Are X)
are you sure your trans has a LSD?
Old Apr 15, 2006 | 12:22 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: is my LSD busted? (non-VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by non-VTEC &raquo;</TD></TR><TR><TD CLASS="quote">are you sure your trans has a LSD?</TD></TR></TABLE>
That, and when you spin one wheel, what is the other doing? Staying still or spinning the opposite way?
If your LSD is busted, it's a pretty good chance you're going to hear some things clanging around in there when you drive (if you are even able to), or spin the wheels. Mine certainly went out with a bang.
Old Apr 19, 2006 | 03:49 PM
See Are X's Avatar
Default Re: is my LSD busted? (shamoo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shamoo &raquo;</TD></TR><TR><TD CLASS="quote">
If your LSD is busted, it's a pretty good chance you're going to hear some things clanging around in there when you drive (if you are even able to), or spin the wheels. Mine certainly went out with a bang. </TD></TR></TABLE>
when I spin one wheel, the other wheel spins in the opposite direction. Transmission does not make any sounds when spinning.
Old Apr 19, 2006 | 07:38 PM
postman's Avatar
depends on lsd, if i remember like a quaife 8 pinion will spin the other way, i believe type-r is this way, and a friction lsd will do the same. but i also might not be remembering correctly
Old Apr 19, 2006 | 08:18 PM
Chiovnidca's Avatar
Default Re: is my LSD busted? (postman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by postman &raquo;</TD></TR><TR><TD CLASS="quote">depends on lsd, if i remember like a quaife 8 pinion will spin the other way, i believe type-r is this way, and a friction lsd will do the same. but i also might not be remembering correctly</TD></TR></TABLE>
A clutch type will both spin the same direction.
b17eg
Jul 10, 2007 06:41 AM
93FastLs
Feb 28, 2005 05:44 PM
Funnyclub
Feb 12, 2005 03:33 PM
Kp_VtekNiks
Jan 11, 2005 04:53 AM
ls95hatch
25
Oct 3, 2003 10:48 PM
