Removing key beeping
Old Apr 14, 2006 | 11:21 PM
bma1818's Avatar
Default Removing key beeping
I have a 97 honda civic ex coupe and I was wondering how to remove the key beep sound, so I can listen to my music without hearing that annoying sound. thankx
Old Apr 14, 2006 | 11:41 PM
thahuhstunna's Avatar
Default Re: Removing key beeping (bma1818)
hahahaha
Old Apr 14, 2006 | 11:51 PM
faejai's Avatar
Default Re: Removing key beeping (thahuhstunna)
just connect ur deck wire, yellow + red together and itll work without having to putting key in, its direct power... but remember to always remember to turn off the deck b4 leaving ur car!
Old Apr 15, 2006 | 12:06 AM
CYM19z's Avatar
whatever.. i want my key beep back...
took apart my stearing colum.. messed aroudn w/ an alarm & lights & lost tha key beep.
i dunno where it went...
Old Apr 15, 2006 | 12:46 AM
HiProfile's Avatar
The civics I've been in only beep with the keys in while the door is open.
Old Apr 15, 2006 | 02:30 AM
E46Kid's Avatar
Default Re: Removing key beeping (HiProfile)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HiProfile &raquo;</TD></TR><TR><TD CLASS="quote">The civics I've been in only beep with the keys in while the door is open. </TD></TR></TABLE>
Close the damn door and that will fix and that is the solution to your problem
Old Apr 15, 2006 | 07:00 AM
doodooheadfart's Avatar
i wouldn't mind knowing how to remove this
*BUMP*
Old Apr 15, 2006 | 07:31 AM
Econo'Box's Avatar
Default Re: (doodooheadfart)
Right beside the drivers seat on the left side lift up the carpet and there is a little plug the connects to the sensor that tells if your door is open. Just disconnect the plug and your problem is solved. This also makes your dome light not work. If you really want to listen to your music out of the car without it beeping just role down the windows. And if you really want to leave the doors open you can install a switch to that line so you can choose when you want it and when you don't.
Old Apr 15, 2006 | 07:44 AM
93gsrhatchbrid's Avatar
my 93 civic did it until i removed the door sensor. it only beeped when the door was open. consequently, i like to listen to my radio while working on my car. that is why i removed mine. however, this also disables the auto dome light from the driver's side(i think). i haven't done a full blown research on it but you can.
Old Apr 15, 2006 | 08:09 AM
is there anyway todo it without losing the dome light?
Old Apr 15, 2006 | 08:27 AM
Syndacate's Avatar
yeah, find the chime, and unplug it
Old Apr 15, 2006 | 10:34 AM
bma1818's Avatar
how do you remove the door sensor? Because I like to work on my car with the music on and the doors open.
Old Apr 15, 2006 | 06:49 PM
Econo'Box's Avatar
Default Re: (bma1818)
Lift the carpet up beside the seat and just pull the electrical connection off. There you go no more beeping. I forgot where the chime is at I helped my friend take his out on a newer model. If you want to keep the dome light follow the wiring diagram in a manual to find it, should't take too long.
( It's the carpet on the left of the driver's seat. You lift up the plastic panel on the door sill and the carpet is attached to it. Leave the carpet attached and just unhook the connector.)
Old Apr 16, 2006 | 07:49 AM
Default Re: (tabrisakakaoru)
thanks
Old Apr 16, 2006 | 07:55 AM
Syndacate's Avatar
Yeah, but the ignition's got to be on for the radio to work..unless you give the radio direct power, so when the ignition's on...the key's in the ignition (unless you stole the car), either way, the key has to be in when he's listening to the radio w/ the doors open
Old Apr 16, 2006 | 11:32 AM
if anyone knows where the chime in an ej8 it would be greatly appreciated
Old Apr 17, 2006 | 01:59 AM
Evolution-93-Ex's Avatar
From: Your mommas bed, that might be true too ..., So Cali, USA
PUT a piece of tape over it haha ghetto rigged thats what i did
Old Apr 17, 2006 | 05:05 AM
if i could find it!
Old Apr 17, 2006 | 08:16 AM
pinoyboiwonder's Avatar
push the door sensor together and duct tape it. the door sensor is near the door jambs. like its flush where the door latches or something.
Old Apr 17, 2006 | 08:30 AM
suspendedHatch's Avatar
Default Re: (pinoyboiwonder)
The door pin trick is a stupid idea. I'm guessing none of you have alarms. The stereo trick is a slightly better idea. But I have the best yet. Turn the key on and open the door. Now you have a continuous beeping for you to track down. Remove your lower dash cover and follow the sound. Stupid. Why would you beg for an answer on the internet?
Depending on what kind of work you're doing to the car, I wouldn't recommend doing it with the key on.
Old Apr 17, 2006 | 08:47 AM
the soL that could's Avatar
NEW TOPIC: ****... locked my keys in my car. didn't beep to warn me.
Old Apr 17, 2006 | 10:34 AM
SHG_Beans's Avatar
Default Re: (suspendedHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by suspendedHatch &raquo;</TD></TR><TR><TD CLASS="quote">The door pin trick is a stupid idea. I'm guessing none of you have alarms. The stereo trick is a slightly better idea. But I have the best yet. Turn the key on and open the door. Now you have a continuous beeping for you to track down. Remove your lower dash cover and follow the sound. Stupid. Why would you beg for an answer on the internet?
Depending on what kind of work you're doing to the car, I wouldn't recommend doing it with the key on.</TD></TR></TABLE>
word
Old Apr 17, 2006 | 10:44 AM
Frozen E's Avatar
H-T White Ops
Is your car that different from mine? In my EM1 I just have to turn the key to the on position and the door thing stops.
Old Apr 17, 2006 | 10:45 AM
Skookem's Avatar
okay, well if i remember right the chime/beep is coming from inback of the fuse box. The easiest way to remove this beep, is remove the grounding wire from the combination switch. Im pretty sure its a single wire on the combination switch towards the keyhole that grounds out when your keys in there. Let me know if im right.
Old Apr 17, 2006 | 10:56 AM
wheelmanbg's Avatar
I don't know if they are the same but here is how i disabled mine on my 95
https://honda-tech.com/zerothread?id=1587320
And BTW the door pin trick is a stupid idea
