Best way to line up my eg headlights?
I was wondering what the best way to line up my eg headlights were because i have a gap between my headlight and the hood. Its were the corner meets the hood they kind of sag down. please help
Best bet would be take off the front bumper. and loosen all the bolts for the lights. Try and do this in a garage or against a wall of some sort. Adjust them as you would like them to look then tighten the bolts back up. But before you call it a day make sure your beam is aligned(hence against a wall) you will be able to see if it is correctly lined up. Good luck
Heycoop Racing
Jan 18, 2013 09:30 AM
