HELP: Check Engine Light
Old Apr 14, 2006 | 04:44 PM
Speed_69's Avatar
Default HELP: Check Engine Light
how do you reset your check engine light?
car: 1998 Honda Civic Si(Canada); in the us 1998 Honda Civic EX
Old Apr 14, 2006 | 04:48 PM
Syndacate's Avatar
disconnect the negative battery terminal for 20 mins or so will clear the ECU....
If it doesn't shut off after you start it back up, then u can't shut it off until you fix the problem that's causing it..
Refer to the codes stick post at the top of this forum for information on pulling codes w/o a computer
parisbaby
Oct 22, 2017 03:24 PM
ahron
May 22, 2008 08:47 PM
sirjmj
Mar 25, 2008 10:42 PM
redludevtec
Aug 15, 2004 04:00 PM
taibui
Mar 23, 2004 02:44 PM
