will my rims fit??
Old Apr 14, 2006 | 02:58 PM
DuVaL rAcEr's Avatar
Default will my rims fit??
ok heres the deal im buying a set of 16x7 rims with 215/50 tire i plan to drop my hatch 4 inches to get that slammed look will the wheels fit???i tried to search it but server is down... please help...
Old Apr 14, 2006 | 03:00 PM
kiddcarbuff's Avatar
if the bolt pattern on the wheels is 4x100 you should be good as long as you have the right offset also
Old Apr 14, 2006 | 03:01 PM
schardbody's Avatar
4" good luck.
Old Apr 14, 2006 | 03:07 PM
TurboEM1's Avatar
Default Re: will my rims fit?? (DuVaL rAcEr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DuVaL rAcEr &raquo;</TD></TR><TR><TD CLASS="quote">ok heres the deal im buying a set of 16x7 rims with 215/50 tire i plan to drop my hatch 4 inches to get that slammed look will the wheels fit???i tried to search it but server is down... please help...</TD></TR></TABLE>.
Heres a tip for honda-tech. PROVIDE MORE INFO
What year hatch?
215/50/16 is definately to large of a tire and is very wide. It would probably rub on a moderate drop nevermind your 4" drop.
your not going to be able to drop your car 4" especially with 215 tires. drop 2"'s and see how you feel. and get the right size tires
as far as rims fitting. 4x100 bolt pattern
Old Apr 14, 2006 | 03:22 PM
its a 92 civic hb... if i went to a 15x6.5 would it be possible with a 205/45 tire
Old Apr 14, 2006 | 03:24 PM
schardbody's Avatar
nope. it will be hard to drive w/ any sized tire even 15" w/ 4" drop on a civic. i have a 92 hatch as well, and im dropped right under 2" on 205/40/16 and they dont clear by much. 2.5" w/ even the smallest tires will be about as much as you will need to lower it.
Old Apr 14, 2006 | 03:27 PM
ok... thanks everybody
CBL9
Feb 5, 2009 09:12 AM
noidg101
Jan 15, 2009 09:41 AM
EMphaticONE
17
Dec 15, 2004 06:45 AM
Philbert
Apr 14, 2003 05:48 PM
