ECU HELP!!!!
Old Apr 14, 2006 | 02:54 PM
jpnucrx's Avatar
Default ECU HELP!!!!
My car runs fine and is really strong....today tho it was back firing alot so i figured it was the plugs...i look at them and they are fine...
I look at my ecu to see if i am throwing any codes...they light doesnt blink at all.
I know you put the ignition on and watch it....but it doesnt blink?!?!
Does this mean i have a bad ecu?....and what could have caused it?
BTW..already searched...no answers
Old Apr 14, 2006 | 05:25 PM
jpnucrx's Avatar
Default Re: ECU HELP!!!! (jpnucrx)
Anybody???...
TTT!!!
I really need some help...and the search function is temporarily disabled
Old Apr 14, 2006 | 06:21 PM
g-ride-si's Avatar
if the ecu doesnt flash right when you put the key in the run position there is something wrong with it.
Old Apr 15, 2006 | 12:07 PM
jpnucrx's Avatar
Default Re: ECU HELP!!!! (g-ride-si)
True...but today ...i pulled my o2 sensor out to see if it would throw a code...and the check engine light came on and it flashed for the 02 sensor...but it still doesnt come on as soon as i turn the car on...yet it flashed when the CEL was on!! WTF?
Any ideas??
Old Apr 15, 2006 | 01:04 PM
jlicrx's Avatar
normal condition is that when you turn your ignition switch to the on position, the Check Engine Light will come on for 2 seconds, then go out - if you have no codes stored the ECU LED will not be on nor will it be flashing - it only flashes when it has a code stored - it will continue to flash everytime you turn the ignition switch to the on position, even if the Check Engine Light is not on - it will continue until you reset the ECU - if you have a Check Engine Light and you turn the ignition switch off, obviously it goes out, however, the next time you turn it on, the CEL will be on for 2 seconds and then go out, unless it detects another problem for which it hasn't already stored a code
phiberoptik
Dec 6, 2003 05:06 PM
iGoneRacing_GSR
Nov 17, 2003 08:25 AM
TurboRedSi
Jul 17, 2003 10:59 PM
nek0
Jul 9, 2003 04:49 PM
Herbiluvbug
Mar 12, 2003 04:05 AM
