93 accord brake issues......
Old Apr 14, 2006 | 02:48 PM
thelate1's Avatar
Default 93 accord brake issues......
basiclly when the a/c is on, the brake pedal is sinking to the floor. now i know what your thinking, brake master cylinder right? ok, but if i turn a/c off pedal works fine/normal. wouldn't it do it all the time if it was the brake master cylinder going bad? could this be a vac leak somewhere? the car is an auto also, so i wasn't sure if there was a sensor that could be bad and attributing to this problem. any help is greatlly appreciated.
thanx.
Old Apr 14, 2006 | 03:07 PM
pos_cd5's Avatar
Default Re: 93 accord brake issues...... (thelate1)
my first guess is...check out your brake booster...
Old Apr 15, 2006 | 07:00 AM
thelate1's Avatar
Default Re: 93 accord brake issues...... (pos_cd5)
so if it is the booster, wouldn't it do it all the time? it seems odd that it's only when the a/c is on.
Old Apr 15, 2006 | 07:10 AM
accord-pro's Avatar
it is normal that the brake pedal sinks slightly when you put the a/c on,, but if yours sinks totally to the floor / you might have internal master cylinder leak
Old Apr 15, 2006 | 08:01 PM
Dmc1's Avatar
Default Re: 93 accord brake issues...... (accord-pro)
Yeah my guess would be the master cylinder to. The fluid get old and full of water condensation and justs the piston in the cylinder so that is can no longer hold a seal and the pressure just bleeds off as you hold the brake down. P Adams helped me with that a few weeks months ago. but my car didn't even have ac at the time.
Old Apr 15, 2006 | 10:48 PM
pos_cd5's Avatar
Default Re: 93 accord brake issues...... (Dmc1)
i had the same problem with my m/c...but he says this ONLY happens when he turns on the A/C, if it was the m/c this would be all the time or once in awhile, regardless if A/C was on or not...either this is a bigger problem then we think, or he needs to do a little more diagnosting
Old Apr 15, 2006 | 11:28 PM
accord-pro's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pos_cd5 &raquo;</TD></TR><TR><TD CLASS="quote">i had the same problem with my m/c...but he says this ONLY happens when he turns on the A/C, if it was the m/c this would be all the time or once in awhile, regardless if A/C was on or not...either this is a bigger problem then we think, or he needs to do a little more diagnosting</TD></TR></TABLE>
there is nothing to diagnose ,, brake system is real simple,, if pedal goes to floor,, you got a hydraulic leak on hte system,, or an internal leak on the brake master cylinder..
like i said it is normal for the brake pedal to sink a bit when a/c engages,, but he is saying that it goes all the way to floor ..
does it go all the way to floor ?? or sinks just a bit and he thinks is going to floor ..
Yo thelate if when pedal goes to floor ,, if you pump it up wil it go up and be firm ?? or does it continue to sink to floor ?
Old Apr 16, 2006 | 12:01 AM
pos_cd5's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accord-pro &raquo;</TD></TR><TR><TD CLASS="quote">
i understand what your saying, and i do know how a brake system works...what i dunt understand is why this ONLY happens when a/c is on, from what i know, and from personal experiance with a bad m/c, this should happen all the time, regardless if a/c is on or not..maybe im missing sumthign here, or maybe i dunt understand the brake system as well as i think, so please fill me in...
Old Apr 19, 2006 | 08:08 PM
thelate1's Avatar
yes, if you pump it it'll get firm.......but will slowly start to sink again.
thanx for the help!!!
another eg
Sep 1, 2015 04:31 PM
AWD: Jeff
Suspension & Brakes
Jul 3, 2010 06:47 AM
LOVEthatDC2
Sep 15, 2009 06:16 PM
4play4dr
Nov 26, 2006 08:35 PM
brandenc
Sep 9, 2002 04:01 PM
