Welding SS Steel to Mild Steel? Welders!
Old Apr 14, 2006 | 02:28 PM
turbotime's Avatar
Default Welding SS Steel to Mild Steel? Welders!
I got a MIG welder and we are trying to weld SS steel to Mild Steel. We know we need a different wire but arent sure which kind... also what gas do I need? co2/argon or something else?
thanks!
Old Apr 14, 2006 | 02:33 PM
B18 CYA's Avatar
Try posting in the welding section of this site. Probably will get a better response
Old Apr 14, 2006 | 02:35 PM
I Have an STD's Avatar
wrenchin'
Default Re: Welding SS Steel to Mild Steel? Welders! (turbotime)
who is trying?? what mild to what stainless? i dont need different wire. steel is steel
Old Apr 14, 2006 | 03:14 PM
turbotime's Avatar
just plain ole stainless mandrel to plain ole mild mandrel
so ihavenastd u say wire speed down and heat up and i will be good just using regular MIG wire?
can anyone confirm
Old Apr 14, 2006 | 04:15 PM
turbotime's Avatar
bump
Old Apr 14, 2006 | 04:28 PM
evilone's Avatar
Default Re: (turbotime)
done it before and it worked out ok
Old Apr 14, 2006 | 04:33 PM
turbotime's Avatar
just using regualr gas and standard MIG wire? do you know the exact type of wire that would be preferred?
Old Apr 14, 2006 | 04:36 PM
abnaasefmb's Avatar
Default Re: (prostock)
the regular wire will work. yes it will rust but its going to rust any way. yes i have done it. your not building a plane, right? good luck.
Old Apr 14, 2006 | 04:37 PM
turbotime's Avatar
awesome this is great news i was worried as hell
what about heat and wire speed? suggestions? im getting it all jethot coated so im not worried about rust
Old Apr 14, 2006 | 05:08 PM
abnaasefmb's Avatar
it depends on the thicknesses of the metal, if this is your first go at welding please practice first, you'll be glad you did.
Old Apr 14, 2006 | 05:17 PM
Tactic$'s Avatar
just test it out on a scrap piece!?
Old Apr 14, 2006 | 05:31 PM
wrenchin'
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbotime &raquo;</TD></TR><TR><TD CLASS="quote">just plain ole stainless mandrel to plain ole mild mandrel
can anyone confirm </TD></TR></TABLE>
i saw you YESTERDAY, you cant call me by my real name?
Old Apr 14, 2006 | 06:21 PM
turbotime's Avatar
hahah yes BRETT but now noone knows who im talking about
Old Apr 14, 2006 | 08:20 PM
wrenchin'
DAN, are u coming to tims tomorrow or are u gonna puss out?
Old Apr 14, 2006 | 09:30 PM
eastbay92cx's Avatar
Default Re: (I Have an STD)
ive done this, welded a stainless pipe to a mild one. mild wire, worked fine. the wire speed and voltage is up to you, whatever is most effective / works for you. good luck
Old Apr 15, 2006 | 11:43 AM
rorik's Avatar
there is a different type of wire that is used for this, I don't remember what it is, but it's like an alloy that's halfway between the other 2..I have some of it, but I''m too lazy to go outside and see what is is..but it's really not a big deal either way.
JDMCRX
Welding / Fabrication
Aug 21, 2009 05:16 AM
twilightprotege
May 22, 2006 04:52 PM
Luserkid
May 27, 2005 04:29 PM
fastcivicboy
Feb 19, 2005 01:02 PM
Greaser
Mar 17, 2003 11:09 AM
