Just Bought a Oil Line kit... missing one piece...
I bought the kit on the left for only $46 (On Ebay ) I was wondering if the piece in the red circle replaces the piece in the green circle in the kit on the right.... also do i need the piece in the blue cirlce to connect my oil line to a oil filter sandwich plate?? if so where can i get it?
any pros/cons about oil filter sandwich plates?
Thankx in Advance...
Re: Just Bought a Oil Line kit... missing one piece... (PhantomX)
The piece with the red circle will be bolt onto the place where the stock sensor is than the sensor would be bolt onto the other end, the oil line will be bolt onto the hole in the middle.
Nothing is missing in that kit, it just they look a little different
Re: (blackccoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackccoupe »</TD></TR><TR><TD CLASS="quote">i meant where is the fitting that goes into the t to connect the oil feed line, ic a 90 but that is prob for the turbo</TD></TR></TABLE>
I also would like to know.....
****ALSO**** When i install my turbo w/ the oil lines.... i dont have to connect anything in the red circle do i?? ( i believe thats the water cooling ports for a turbo....correct me if im wrong)
Modified by PhantomX at 6:47 PM 4/14/2006
Nordy
11-24-2006 09:07 PM
