B20vtec Gurus: Some easy questions...
Is there a difference between b20b and b20 z head gaskets?
I put one on today with a b16 head, im a little concerned about the gasket.
its an OEM gasket and i can get the part #, but when i put it on it looked like there were 2 coolant passages on the exhaust side of the block that were covered
they werent completely covered...but they were covered enough to make me think that an oem gasket should fit better than that. Or i might be on drugs.
Also is there anyway to tell if i have a b16/gsr or b20 water pump.
TIA
they werent completely covered...but they were covered enough to make me think that an oem gasket should fit better than that. Or i might be on drugs.Also is there anyway to tell if i have a b16/gsr or b20 water pump.
TIA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by charlee ricer »</TD></TR><TR><TD CLASS="quote">dood tjis will help SOOOOO much.
http://hybrid2.honda-perf.org/....html
well it help a little....
the part number for the HG is 12251-p8r-004
so i guess they are the same for b20b and b20z
</TD></TR></TABLE>well it help a little....
okman my last shot.
here try this looks more better.i REALLY hopes this works
http://www.c-speedracing.com/h...c.php
yup, thanks boss!
if you look at this pic... http://www.c-speedracing.com/h...9.jpg
youll see the square hole int the blocked covered by round hole on the gasket!!
must be normal, thanks again man
