89 Teg ECU on ZC--Code 8 (TDC)
I just got the 89 Teg ECU for my ZC and im getting code 8 (Top Dead Center sensor) were can I find this and how to fix thanks. By the way did a search and did everything that I found, but im going to double check my distributor make sure everything is O.K. I have the ZC ECU also and get the same code. Thanks in advance.
On the ZC, one TDC sensor is in the distributor and one is on the exhaust cam...
Are you using the distributor I gave you? If so I think the engine wiring is different from the stock Si wiring... Did you install a square plug on your engine wiring harness to connect to the Integra distributor? Two of the wires from the dist plug need to go to the exhaust cam tdc sensor...
Hey whats up Dustin...No I havent installed the new Dizzy, im doing that today but just noticed that when I pluged in the Teg ECU it was throwing a code 8 (TDC) it has the original Dizzy right now from the ZC. So go ahead and plug the new one and that should fix the problem. This might sound stupid but were is the TDC Sensor.
Your right 89 teg ECU runs hella rich it puts out alot of black smoke, my ZC doesnt do that.
Hey me and some buddies are going to Sears Point on the 17th wana join us, that's if your Teg is ready.
Yeah people usually lower their fuel pressure with a B&M Regulator with the Teg ecu.
I don't think my car will be running by then or I'd go man! Stupid broken cars.
Dustin
Dustin
h22_crx
Mar 19, 2006 12:20 PM
VTgringo
Jun 23, 2003 07:28 PM
balistic CRX
Feb 9, 2002 06:03 AM
