stock valves vs aftermarket
Old Apr 14, 2006 | 10:14 AM
Speed Infliction's Avatar
Default stock valves vs aftermarket
I'm not sure about this but i sthink that stock valves are the best to go with compare to aftermarket valves. Correct me if i am wrong. I dont know about the springs retainers and seals though. somebody help me out please
Old Apr 14, 2006 | 10:31 AM
RTW DC2R's Avatar
for what purpose? there are different kinds of aftermarket valves to choose from. stocks are great for most applications. you can use aftermarket valves to increase compression slightly, get them oversized, and they have different tensile strengths and coatings. all depends on your setup and needs.
Old Apr 14, 2006 | 10:34 AM
Default Re: (RTW DC2R)
thinking about running all motor with high compression about 12:1
Old Apr 14, 2006 | 10:36 AM
Default Re: (Fayzeless)
what do you think i should use for a setup like that?
Old Apr 14, 2006 | 11:08 AM
Circuit Star-29's Avatar
If the head is to remain mostly stock, my advice is to use OEM valves... But, if you are getting the head built, might as well go w/ some stainless valves. Get some bronze valve guides installed along w/ the valves, as stainless valves have been known to cause excess wear to oem guides.
Old Apr 14, 2006 | 11:46 AM
RTW DC2R's Avatar
12:1 is not all that high. stock valves are fine for something like that. if you want to boost compression slightly more, you can get flat valves instead of dish(like stock) and you might get up to about 12.3-12.4. then maybe a thin head gasket for a bit more compression. or get some oversized valves, valve job, etc, and increase airflow through the head. there are many options and 12:1 is pretty mild as far as high compression goes.
Old Apr 14, 2006 | 12:07 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW DC2R &raquo;</TD></TR><TR><TD CLASS="quote">12:1 is not all that high. stock valves are fine for something like that. if you want to boost compression slightly more, you can get flat valves instead of dish(like stock) and you might get up to about 12.3-12.4. then maybe a thin head gasket for a bit more compression. or get some oversized valves, valve job, etc, and increase airflow through the head. there are many options and 12:1 is pretty mild as far as high compression goes. </TD></TR></TABLE>
agreed
Old Apr 15, 2006 | 10:00 AM
Default Re: (Circuit Star-29)
Which is better oversized valvesand a head job or stainless steele valves and a head job?
Old Apr 15, 2006 | 11:21 AM
Oversized valves will not be necessary for your build...
I would say that OEM ITR valves will be sufficient w/ a good port-n-polish from the likes of Alaniz (biased ) or some other quality names in the market. Just do a search for port and polish and some names should come up....
Old Apr 15, 2006 | 11:38 AM
so would you go stainles steel with a head job then or would you keep it stock with port and polish?
Old Apr 15, 2006 | 11:52 AM
SkeeRX's Avatar
i have stock style supertech flat valves in my car and they seem to work great..
Old Apr 15, 2006 | 12:25 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fayzeless &raquo;</TD></TR><TR><TD CLASS="quote">so would you go stainles steel with a head job then or would you keep it stock with port and polish?</TD></TR></TABLE>
Reading &gt; You...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Circuit Star-29 &raquo;</TD></TR><TR><TD CLASS="quote">
I would say that OEM ITR valves will be sufficient w/ a good port-n-polish </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Team Teal &raquo;</TD></TR><TR><TD CLASS="quote">i have stock style supertech flat valves in my car and they seem to work great.. </TD></TR></TABLE>
Do you have any numbers for us to measure or is this an opinion? How do you know they work great? Let us know...thats what this thread is about...
Old Apr 15, 2006 | 01:11 PM
Default Re: (Team Teal)
what would you do
Old Apr 15, 2006 | 01:48 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fayzeless &raquo;</TD></TR><TR><TD CLASS="quote">what would you do</TD></TR></TABLE>
Are you serious? Do you even read the posts?
OEM/ P-n-p
baysic r
Jul 7, 2009 08:14 PM
all-mtr-teg
11
May 27, 2008 11:40 AM
Allstar
Apr 30, 2002 07:54 PM
Smoothy
Sep 23, 2001 05:38 PM
