d16 Throttle Body
Old Apr 14, 2006 | 09:50 AM
5lugSlug's Avatar
Default d16 Throttle Body
I've got a d16y8 with a Skunk2 Intake Manifold... my next purchase includes a new throttle body, whats the best throttle body size (diameter) and best brand for the d16?
(Im building up to boost if that helps - this is also my daily driver)
Old Apr 14, 2006 | 10:10 AM
schardbody's Avatar
use an LS TB, cheap, 60mm, and bolts right on. No need for anything bigger, especially until you do boost.
Old Apr 14, 2006 | 10:41 AM
SkoundrelUSA's Avatar
cute little bastard
Default Re: (schardbody)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by schardbody &raquo;</TD></TR><TR><TD CLASS="quote">use an LS TB, cheap, 60mm, and bolts right on. No need for anything bigger, especially until you do boost.</TD></TR></TABLE>
I second this motion
Old Apr 14, 2006 | 11:15 AM
rip94delsol's Avatar
Default Re: (Fat Skoundrel Jr.)
get the ERE(ericks racing) throttle body 72mm tappered to 70 so when you do boost you dont have to change the throttle body. 60 mm imo is small
Old Apr 14, 2006 | 01:20 PM
schardbody's Avatar
60mm is a big upgrade from 56mm. w/out boost that 70mm is going to be way too much.
Old Apr 14, 2006 | 01:31 PM
5lugSlug's Avatar
will i be safe with a 60mm when I do boost? im lookin for somethin i wont have to upgrade later..
im not planning on a lot of boost, just the typical 6-12
Old Apr 14, 2006 | 01:48 PM
schardbody's Avatar
its all up to you, you can gain a little HP by going to a bigger TB, but imo 60 is plenty. you should base it mostly on your HP goal, instead of boost level. if you plan to stay under 200whp (which doesnt sound like alot) then you will be fine w/ the LS TB.
Old Apr 14, 2006 | 06:35 PM
5lugSlug's Avatar
well whose got an LS TB for sale?
Old Apr 14, 2006 | 06:40 PM
Civicse's Avatar
Default Re: (EJacul8)
bigger throttle body = better throttle response not more hp
Old Apr 14, 2006 | 06:43 PM
silverwannabeEM1's Avatar
yep ls throttle body ftw
Old Apr 15, 2006 | 03:52 AM
schardbody's Avatar
bigger TB on a boosted car does equal more HP.
Old Apr 16, 2006 | 01:58 PM
5lugSlug's Avatar
i picked up a TB from an LS today but missing the MAP sensor and gasget.. can i use the D16 TB sensor and gasget?
Old Apr 16, 2006 | 02:24 PM
schardbody's Avatar
use an LS gasket, and your old map sensor, just hook vacuum line to it and connect it to the new TB.
Old Apr 16, 2006 | 04:33 PM
5lugSlug's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by schardbody &raquo;</TD></TR><TR><TD CLASS="quote">and your old map sensor</TD></TR></TABLE>
broke those bolt things that hold it to the TB how do i get/make new ones?!!?
Old Apr 16, 2006 | 07:07 PM
schardbody's Avatar
you can get the bolts from honda, shouldnt be but a few bucks at most, or just take it into a hardware store with you and match them up.
perseverance
Nov 26, 2006 04:32 PM
CivicHatch21
Mar 23, 2005 07:33 AM
_gurusan_
Oct 12, 2004 05:50 PM
B00ST2nR
Nov 26, 2003 12:45 PM
oldbeefcake
Jun 14, 2003 09:05 AM
