lower ball joints
Old Apr 14, 2006 | 09:49 AM
DelSolMarine's Avatar
Default lower ball joints
how much should lower ball joints cost for labor? there have both lower ball joints for like 30 bucks a piece at autozone but whats the labor to have them installed..
Old Apr 14, 2006 | 09:59 AM
Default Re: lower ball joints (DelSolMarine)
bu bu bu bu bump
Old Apr 14, 2006 | 10:09 AM
schardbody's Avatar
about $45-60 a side.
Old Apr 14, 2006 | 10:22 AM
Default Re: (schardbody)
what kinda damage can that cause if there not replaced?
Old Apr 14, 2006 | 10:25 AM
ilu's Avatar
ilu
Default Re: (DelSolMarine)
i know i've been driving on my bad lbj for months with no problems at all. i don't even know if it's broken. stupid midas.
Old Apr 14, 2006 | 10:30 AM
Default Re: (ilu)
well there grease all over my **** obvious theres something in there keeping something lubricated so whats the dealio with that?
Old Apr 14, 2006 | 10:44 AM
schardbody's Avatar
theres a grease boot on the ball joint. but not alot of grease should come from them, if theres grease all over you **** then you should check the cv boot for tears. as for driving w/ bad ball joints, thats up to you. i mean nobody can say that you wont hit a pothole and it just come apart tomorrow, in which case you would most likely veer to that side, hitting any car in the next lane, and possibly causing innocent people injury.
Old Apr 14, 2006 | 10:45 AM
.Ry's Avatar
.Ry
Either your ball joints went to ****, but more than likely the grease is from your CV joint boot ruptured.
killerformula's Avatar
New hondas have sealed ball joints that cannot be lubed. There is lube inside them, but the idea is that greasing them just introduces contaminants. The joint is basically just a ball sitting inside a cup. There is lube inisde to pad the metal on metal contact. If the seal is damaged the lube can escape and grit can get in. Its only a matter of time till the ball joint grinds itself apart. After enough time they can separate completely. On even surfaces you may notice the car wanders a bit and needs a bit more correction than normal. ON bumpy roads you could be all over the place.
Old Apr 14, 2006 | 11:14 AM
jdmsi1320's Avatar
just do the ball joints yourself they are easy. The easiest way the do them is with a big hammer and bang it out takes 10min
Old Apr 14, 2006 | 11:26 AM
hellshock2182's Avatar
Default Re: (jdmsi1320)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmsi1320 &raquo;</TD></TR><TR><TD CLASS="quote">just do the ball joints yourself they are easy. The easiest way the do them is with a big hammer and bang it out takes 10min </TD></TR></TABLE>
I second that I just did mine a week ago. easiest **** I've done.
Old Apr 14, 2006 | 08:11 PM
CardDealer's Avatar
Banned
Default Re: (hellshock2182)
Modified by CardDealer at 2:35 PM 11/16/2006
Kevins89notch
21
Nov 4, 2013 06:17 AM
eurochoi
18
Aug 2, 2012 09:32 AM
ammomel
Jan 3, 2011 06:07 AM
PatrickGSR94
Suspension & Brakes
18
May 12, 2010 09:55 AM
snatch
25
Jul 13, 2005 04:54 PM
