Blown motor? 165-165-80-165
Old Apr 14, 2006 | 06:44 AM
migs's Avatar
Default Blown motor? 165-165-80-165
So I took a road trip the last few days.
Here is what happened:
Went to pass somebody at 6500 RPM and my dump tube fell off. As soon as it fell off, I felt it either hit the car, or loss of power (immediately). So I get to my friends house, my car cant even idle anymore, I have to give it some gas. I look and there is only 1 bolt holding my turbo to my manifold on.
So that would explain the exhaust leak and lack of power (might I add).
I get new bolts and its all fixed. No exhaust leak but I hear a miss in the exhaust note. Like a *blurp*
Compression came back as 165-165-80-165. The famous #3 cylinder is gone.
What usually goes? This is my first turbo motor. Thanks in advance.
Old Apr 14, 2006 | 06:57 AM
wantboost's Avatar
Who is Mr Robot?
Default Re: Blown motor? 165-165-80-165 (migs)
the dump tube wouldnt cause that to happen. you definitely did something. most likely ringlands
Old Apr 14, 2006 | 07:10 AM
D@nnY's Avatar
Default Re: Blown motor? 165-165-80-165 (wantboost)
have you pulled the plugs? check the valves
Old Apr 14, 2006 | 07:14 AM
ef`rolla's Avatar
Is it puffing smoke out the breather or exhaust ? If so what color ?
Old Apr 14, 2006 | 07:24 AM
migs's Avatar
Default Re: (ef`rolla)
The breather isnt blowing smoke nor is oil coming out of that area. I am running straight downpipe, even with my tune, it just blows smoke (fuel) dark color. I pulled the plugs and they seem like it could be replcaed, about 3000 miles on em. Im not a tech guy by any means, it just looks seriously discolored. Thank you for all your help.
Old Apr 14, 2006 | 07:49 AM
redzcstandardhatch's Avatar
something different
how much oil are you losing by driving it?
might be a bent valve, or one thats not seating well..
probably something bad, but who knows.
Old Apr 14, 2006 | 07:57 AM
migs's Avatar
Default Re: (redzcstandardhatch)
I have a Greddy oil cooler so since day 1, I havent been able to read the dipstick right
Fatty_1775
Aug 8, 2006 04:12 PM
ppfalcon
May 1, 2006 09:26 PM
migs
Apr 1, 2006 10:03 AM
JunIntegra
Jan 8, 2004 04:57 AM
ScrapinSi
Nov 26, 2003 10:36 PM
