wtf this ever happen to a fuse in your car?
Old Apr 14, 2006 | 04:49 AM
si0385.'s Avatar
Default wtf this ever happen to a fuse in your car?
the fuse caught fire it should have popped way before this happened.. it burnt up a part of my fuse box too so i dont think i can get another fuse in there
its a 20a for my wiper motor
Old Apr 14, 2006 | 04:56 AM
HondaJack's Avatar
Default Re: wtf this ever happen to a fuse in your car? (si0385.)
Yikes!!!!
That sucks.
Old Apr 14, 2006 | 05:00 AM
Deviation's Avatar
Never had that happen before. Impressive.
Old Apr 14, 2006 | 07:33 AM
Tippyman's Avatar
Wow! That's a hell of a blown fuse!
Old Apr 14, 2006 | 07:48 AM
djphonics's Avatar
Default Re: (Tippyman)
Did you get the fuse at AutoZone. If so, that might be your answer.
Old Apr 14, 2006 | 08:19 AM
ludesrv's Avatar
I've had fuses melt before, but in an amp, not in a fuse box....
Old Apr 14, 2006 | 08:35 AM
si0385.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tippyman &raquo;</TD></TR><TR><TD CLASS="quote">Wow! That's a hell of a blown fuse!</TD></TR></TABLE>
thats the problem the fuse didint blow it just got realy hot and melted... i think it fucked up the fues box, it melsted the spot that the fuse goes in... i might just rewire the box and use a differnet spot for the fuse...
gota get it fixed soon the rainy season is coming down here in florida
Old Apr 15, 2006 | 12:15 AM
FOMULA91's Avatar
Default Re: (si0385.)
How would a wiper motor fuse burn like that?
Old Apr 15, 2006 | 01:34 AM
Rywire's Avatar
Default Re: (FOMULA91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FOMULA91 &raquo;</TD></TR><TR><TD CLASS="quote">How would a wiper motor fuse burn like that?</TD></TR></TABLE>
musta been Veetak!
Old Apr 15, 2006 | 03:34 AM
Blaze45's Avatar
Brrraaaap!
Default Re: (droppedcrxsi)
It might be the wrong fuse for the wiper motor, check n make sure that its a 20 that goes in there, cause if not, and someone put the wrong fuse in there instead of the fuse poping, it just heated up untill it melted.
Old Apr 15, 2006 | 03:45 AM
jc836's Avatar
Unless this is the original fuse-could be mismarked-that is unlikely.
Have you tested the wiper motor to see if it is jammed-this will cause a fuse to heat up. I have never seen this type of fuse fail this way. You can contact BUSS or Littlefuse (manufacturers) and ask them. Make sure NOTHING else is either on this circuit, correct rating, and most important check for shorts/frayed or damaged wiring in the harness.
Old Apr 15, 2006 | 04:25 AM
ne3ek's Avatar
Default Re: wtf this ever happen to a fuse in your car? (jc836)
no it has not, god that sucks.
Old Apr 15, 2006 | 07:26 AM
JUN.'s Avatar
Default Re: wtf this ever happen to a fuse in your car? (ne3ek)
Maybe you wired more wires to that line and your current line burned, causing less amps to flow. since the line is forcing amps, you melted the fuse....
thats happening to my clusted light....
I need to change it, I cant ride my car at night llool
Old Apr 16, 2006 | 09:33 AM
si0385.'s Avatar
no i havent checked whe wiper motor yet to see if it was jamed its a good idea though..
im on vacation right now so im gona check it when i get back home and get my tools..
all i checked for so far was the wires behind the fuse box to make sure the jackts were on the wires to make sure there wouldint be a fire
the thing i dont get is there is nothing else on that circut and i wasint using the wipers the whole ride down but i did smell something burning... but stupid me never checks **** like this out till something breaks lol... the only reason i found it was cuz i found the fuse on the floor looking just like that
Old Apr 16, 2006 | 09:41 AM
JapJunkie's Avatar
Default Re: (djphonics)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djphonics &raquo;</TD></TR><TR><TD CLASS="quote">Did you get the fuse at AutoZone. If so, that might be your answer.</TD></TR></TABLE>
Old Apr 16, 2006 | 11:32 AM
crxcess's Avatar
Default Re: (JapJunkie)
I got a 93 mustang that melted 30amp fuses for an electric fan setup. the fan motor was going bad and causing the fuse to melt. Once I replaced the fan, it stopped. but the fuses looked just like that.
Old Apr 17, 2006 | 05:38 AM
si0385.'s Avatar
Default Re: (crxcess)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxcess &raquo;</TD></TR><TR><TD CLASS="quote">I got a 93 mustang that melted 30amp fuses for an electric fan setup. the fan motor was going bad and causing the fuse to melt. Once I replaced the fan, it stopped. but the fuses looked just like that.</TD></TR></TABLE>
thanks man i think thats my problem i just tried putting another 20a in it and watched it and it just got hot as expletive but i pulled it out before it could melt... it doesint seem like its grounding out just like a bad wiper motor... i guess ill try replacing it
this ever happen to andybody else?
Old Apr 17, 2006 | 05:54 AM
G0crxG0's Avatar
Nope, never seen anything like it.
I take it your fuse box is OK then?
If you need a new one, I got one you can have if needed. LMK if you melt your box the rest of the way.
Oh, and with Florida having that rainy season you described, tell me why I bought a CRX from somebody down there with no wiper fluid squirters? made for an unsafe ride home
Old Apr 17, 2006 | 06:02 AM
gsxr1k05's Avatar
Default Re: (G0crxG0)
with the motor burning up, it would pull more amps. which would explaine the fuse problem. maybe the brushes on the moror went bad... never seen that **** before though.. damn.. that sucks hardcore
Old Apr 17, 2006 | 07:25 AM
si0385.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by G0crxG0 &raquo;</TD></TR><TR><TD CLASS="quote">Nope, never seen anything like it.
Oh, and with Florida having that rainy season you described, tell me why I bought a CRX from somebody down there with no wiper fluid squirters? made for an unsafe ride home</TD></TR></TABLE>
thanks ill keep your fuse box in mind...
i have no fluid squirters down here its no problem not having them... when i was in new york it was a different story you need the squirters to wash off the salt
Old Apr 17, 2006 | 08:12 AM
G0crxG0's Avatar
Oh yeah, I guess you guys use sand, not salt huh? never thought of that. Either way though, dirty roads and traffic will make your windshield dirty, it's only OK if it's raining so you can wipe it off, but if it's just spray from peoples tires, it's only gonna get smeared.
If you need the fuse box don't hesitate to ask, this is why I kept it. How often do you run into a prob with the fuse box? not often......If you need it, send me like 2 or 3 bucks to cover s/h and it's yours
Hanmin
May 16, 2008 02:17 AM
integrakid
Dec 11, 2005 05:57 PM
EliteRacer05
Aug 5, 2005 10:01 AM
playerzz
Nov 11, 2003 12:22 AM
