Re-did brake lines....fluid only goes to 1 wheel??????
Old Apr 14, 2006 | 01:12 AM
b.d.racing's Avatar
Default Re-did brake lines....fluid only goes to 1 wheel??????
I re-did all my brake lines since the car is stripped down now and I only seem to get brake fluid going to the rear drivers side wheel. I've got all the lines going to the proportioning valve just like they're supposed to, no leaks at any of the fittings, and no crazy bends that would block flow. When I press the brake in I get flow going through the lines going to the proportioning valve which I know because of having to redo the fittings. Can a proportioning valve block fluid flow? Somebody hook me up with some knowledge because this whole thing was a nightmare to begin with.
Old Apr 14, 2006 | 07:01 AM
b.d.racing's Avatar
Default Re: Re-did brake lines....fluid only goes to 1 wheel?????? (b.d.racing)
need answers
Old Apr 14, 2006 | 07:58 AM
thesmogman's Avatar
Did you bleed them in the correct order?
1. Front left
2. Right rear
3. Right front
4. Left rear
Let's go from there.
Old Apr 14, 2006 | 08:52 AM
b.d.racing's Avatar
Default Re: Re-did brake lines....fluid only goes to 1 wheel?????? (thesmogman)
How do I bleed when there's no fluid?
Old Apr 14, 2006 | 10:17 AM
robbieshonda's Avatar
Unless you have someone helping you gravity bleed them. fill the res, leave the cap off open all 4 of the bleeders and let them flow. it will take a while.
And the dude above said bleed them in the correst order because eventually the fluid will come out and im not tring to insult your intelegance but you have someone helping you right? pump it hold it have them open the bleeder when the pedal is down close it, then repeat
Old Apr 14, 2006 | 04:48 PM
b.d.racing's Avatar
Default Re: Re-did brake lines....fluid only goes to 1 wheel?????? (robbieshonda)
Yeah I know how to bleed brakes but I've been pumping and still nothing
Olivier Maltby
Suspension & Brakes
Dec 13, 2012 08:26 PM
Jaydeep
Jun 25, 2012 09:25 PM
hermtm2
May 8, 2009 10:33 AM
b.d.racing
Apr 14, 2006 08:53 AM
LL
Jul 23, 2001 04:07 PM
